General Panda problems
pinkgirl
lowestoft
Hi
I am having problems with my panda (K Reg 1000 fire pink limited edition)
When i turn off the engine it still runs on for about 10 seconds it happens when the engine temp is about 90. It is also backfiring a little whilst de accelarating. I have had the plugs changed and had fuel system cleaner in the petrol but to no avail can anyone help?
Initial reading of your post would indicate possible pre ignition. Need to check points and timing.
Rgds.
Would help to know if it is carburetor or SPI. If carb, the idle shut off valve might be jammed. It's supposed to block the idle circuit on the carburetor when the ignition is switched off and prevent running on.
I would have thought that a 'K' reg Panda would be running the electronic distributor? :confused: If so, points won't be an issue.
Timing could well be out, or there could be an air leak on the induction side. Probably a simple problem that just needs locating and solving to cure it. (y)
All of the "Pinks" were points ignition and they were some of the last Panda's to enter UK with a carb.
:yeahthat:
christopher watson said:
the 999cc FIRE was also available with SPI :)
coz i got one of the first CAT models (K Plate) with the vertically mounted Cat(y)
Re: Panda problems Update
Pinkgirl ( Dawn ) reports that points replaced and timing reset has cured the problem. Offers thanks to all.
Rgds.
nuovapanda said:
after all the above, then check your idle speed too.
Sorry to hijack but how do you change the idle speed? Mine seems a little low. Thanks
