yup, why not much appreciated.Jaff_Fox said:Yup I did, it was off some gent who specialised in carb refurbs.. if you're interested I'll get his phone number for you.. I believe he will post..
Tony M said:but the Panda carb isn't glamourous enough to put details up online about.
Tony M said:yup, why not much appreciated.
I have found a few places that have got websites but the Panda carb isn't glamourous enough to put details up online about.
Jaff_Fox said:Mayson And Solomon
Stafford ST21 6AA
01785 851990
I just asked for a weber 32TLF and he knew exactly what I needed. The kit had new needle valve, gaskets and diaphragms in it.. cost £16.50.
I've also got a step by step guide on how to rebuild the 32TLF saved on my puter here if it helps anyone..
Mine runs like new.. I'm truly chuffed with the results..
Hope this helps
e505jpy said:From certain angles it really does tent my trousers in the way only Uma Thurman with an Uzi can!
It most certainly does Jaff... the carb on mine has been played with to the point of it losing the plot. my dad turned the mixture screw 3 whole turns clockwise before he met anything. So it's well out... thought it could probably do with a good clean also as it's most likely been standing on a shelf for a while, as the the previous owner was using an LPG kit on the engine.Jaff_Fox said:Mayson And Solomon
Stafford ST21 6AA
01785 851990
Hope this helps
Tony M said:It most certainly does Jaff... the carb on mine has been played with to the point of it losing the plot. my dad turned the mixture screw 3 whole turns clockwise before he met anything. So it's well out... thought it could probably do with a good clean also as it's most likely been standing on a shelf for a while, as the the previous owner was using an LPG kit on the engine.
what format is the setup guide in JF? any chance you email it across?
I'll give the fellow a call.
if the guide is in .jpg format you can upload it as an attachment to a message Jaff...Jaff_Fox said:The file is in .jpg format.. I'll try to remember to send em over tonight but you might need to give me a poke if I forget... Let me know how you get on with that chap as I have no idea how many he had left...
