commiepanda
Hello.
I have a 93 panda ( my first one ) and I have a grumbling noise coming from the transmission. With the car running and the trans. in neutral with my foot off the clutch pedal, I get a grumbling noise. When I push on the clutch pedal, the noise goes away. I also get some noise in first gear when driving and a little less noise from second, also when driving. 3rd through 5th are quiet. I susspect either low fluid in the trans. or worn bearings in the transmission itself. Embarrassing though it may be, I can't seem to find the check/fill plug for the trans. to check this possibility.
Does anyone know what might be my problem just by my simple noise diagnosis?
Thanks kindly for any help.
