Originally posted by John H
Originally posted by Enzo
If you worry about lack of lubrication during the first start after an oil change you could fill your new filter before fitting it...so the oil will reach the rings more quikly
If you try filling the filter on the FIRE engine before fitting, it all pours out up your shirt sleeve when you fit itB) - the cartridge is mounted horizontally.
Eh eh...I well know it's impossible to do it,but this is an advice given by a Fiat mechanic...I'd like to see him at work
!BTW I wouldn't worry about the 2 or 3 second while the oil lamp stays on after an oil change, there remains a film of lubricant between the metals which is enough to avoid damages.
Passion has neither brands nor models!
La passione non ha nè marche nè modelli!
