Thread Tools
Old 13-02-2006   #1
1 Key operation!
Sprox's Avatar
Trader Rating: 2
Sprox has donated!
Unhappy Electronic Ignition Thingy
If I've got a CArburettor and a Distributor - What else do I have controllin the ignition? There is a small box marked with a lightning bolt under the air intake -Is there a coil?
DO these electronic boxes ever break down?
Should I have a Coil?
I've got a new carb and a new distributor but something is still not right - haven't got maximum power - so to speak!
Help!
Sprox is offline Reply With Quote Quote
Old 13-02-2006   #2
Trader Rating: 5
christopher watson has donated!
Goodluck Santa Champion, Pogo Panic Champion, Weapons Of Mass Destruction Champion
Re: Electronic Ignition Thingy
(voice of scotty). Its no good captain, i cant get maximum power, i think the coil is off line
christopher watson is offline Reply With Quote Quote
Old 13-02-2006   #3
Northern Ireland
JimMagill's Avatar
JimMagill has donated!
Quote Originally Posted by Sprox
Help!
If your coil is breaking down it would get hot (very hot)
I think you need to find out whats wrong or else you'll be replacing radom parts till you bank balance is empty and the cows have come home.
Check the usual stuff like timing, mixture, is it getting fuel? whatst the plug condition like etc. (sorry if you've already done this)
Jim
LittleFiatAdventure
JimMagill is offline Reply With Quote Quote
Old 13-02-2006   #4
1 Key operation!
Sprox's Avatar
Trader Rating: 2
Sprox has donated!
Jim[/QUOTE]
Yep! all been done! It's got loads of flat spots Captain!
I suspected that box with the lightning bolt on for a long time!
I'll check it out!
Will a Computer test bring up a result? I'm not a very good mechanic - I learned on a Fiat 126 and they've inly got pedal power!
Old 13-02-2006   #5
Northern Ireland
JimMagill's Avatar
if you've got a coil it be behind the engine under the spare wheel.
what year is the car?
Jim
LittleFiatAdventure
Old 13-02-2006   #6
1 Key operation!
Sprox's Avatar
Trader Rating: 2
Sprox has donated!
H plate November 1990
Old 13-02-2006   #7
Northern Ireland
JimMagill's Avatar
I've forgotten, is it the blue 4x4 or have you changed it??
Jim
LittleFiatAdventure
Old 13-02-2006   #8
1 Key operation!
Sprox's Avatar
Trader Rating: 2
Sprox has donated!
Yes, It's Mr Bump H739 FLT, 63k 4x4
Old 13-02-2006   #9
Northern Ireland
JimMagill's Avatar
Right, so it's Electronic then
At the end of the day it only generates a spark when a sensor tells it too so it shouldn't be that hard to work out if your not getting full power to the plugs...
If it was the coil then it's usually ok when cold but plays up when hot as the coil overheats.... Have you looked at that yet?
Jim
LittleFiatAdventure
Old 13-02-2006   #10
1 Key operation!
Sprox's Avatar
Trader Rating: 2
Sprox has donated!
I'll see if I can find a Coil under the spare - I know what the 126 ones looked like so I'll hopefully find it - I'll take me camera!
Old 13-02-2006   #11
Northern Ireland
JimMagill's Avatar
yeah, it's mounted under the spare on the passenger side, you can't miss it once the wheel is out...
Jim
LittleFiatAdventure
Old 13-02-2006   #12
1 Key operation!
Sprox's Avatar
Trader Rating: 2
Sprox has donated!
Let's see if this picture of my engine bay appears on your screen!
Old 13-02-2006   #13
1 Key operation!
Sprox's Avatar
Trader Rating: 2
Sprox has donated!
Hmmm - it doesn't look like a coil to me!
There is plenty of fuel in the in-line filter too.
Old 13-02-2006   #14
Ban the Mongol rally
Alan.D's Avatar
Trader Rating: 4
Alan.D has donated!
The little bit of the jack is just about pointing to it.
Before doing anything....
FFS DISCONNECT THE BATTERY.
Alan.D is offline Reply With Quote Quote
Old 13-02-2006   #15
Alan.D's Avatar
Trader Rating: 4
Alan.D has donated!
and yes that's the coil the lead from it goes to the distributor cap, it doesn't look like an old type coil but it's still a coil
Thread Tools
(T) Uno Breakerless Ignition geeker Uno 5 26-09-2005 14:35
(T) ground when ignition is off Firewarrior Cinquecento / Seicento 4 02-03-2005 21:37
(G) uno mk1 ignition switch wiring coolhand_mike Uno 0 07-10-2004 00:58
(G) Electronic Oil Level Indicator Lou Ulysse 2 12-05-2004 20:38
(T) Ignition cuts out :-( quater Punto (Mk2/2b) 2 10-05-2004 22:59
