Old 29-01-2006   #1
Engine swap question
I have the fiat Panda 1000 fire model. I asked this question on many forum world wide but never got really an answer...
I have a chance to buy for 300 the fiat uno 1.3 turbo engine with gearbox...Know, deos anyone know if the uno turbo engine fits in a fiat panda model?
skarbanan is offline Reply With Quote Quote
Old 29-01-2006   #2
It's a bit noisy
FuzzyPanda's Avatar
Trader Rating: 1
FuzzyPanda has donated!
Re: Engine swap question
I believe it does. The Lancia Y10 is more or less a tarted up Panda and is available with the same/a similar turbocharged engine.
FuzzyPanda is offline Reply With Quote Quote
Old 29-01-2006   #3
Plug has donated!
Now that sounds like an interesting idea..
Cheers,
Plug
Plug is offline Reply With Quote Quote
Old 29-01-2006   #4
Well the uno turbo is a cheap engine relatively. The 1.3t has 100hp and that's enough for the panda....
Hope to fit the engine and gearbox with no big complications in the panda.
Old 29-01-2006   #5
arc
this is where i stand
arc has donated!
the Y10 doesn't use a FIRE engine, the 1.3 uno engine is not a FIRE engine. the 1000 panda engine is a FIRE. i wouldnt expect it to go in very easily tbh. custom engine mount time.
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 29-01-2006   #6
Has anyone tried to put into a panda a fiat uno turbo engine?has any experience on thaht engine fiting other cars?
Old 29-01-2006   #7
arc
arc has donated!
ive seen it put into a cinq and a sei before. with the centos, swapping from the 1108 FIRE engine to the 1242 FIRE engine is easy. swapping from the old 899/903cc OHV engine to a FIRE engine is not easy. And swapping from the 1108 FIRE engine to a UT or GT engine (both non FIRE) is not easy. A lot of work goes into them swaps.
What *might* work, is getting the Y10's engine mountings and using them on the UT engine. IF they fit the panda and IF they line up with the UT engine.
Old 29-01-2006   #8
Oooo now i'm feeling sad
That means that maybe the uno turbo engine is not the one for the panda...
What do you thnk which engine would be a great engine o fit the panda if not the UT?
Old 29-01-2006   #9
arc
arc has donated!
i'm by no means an expert with Pandas. I don't know what fits or not. I was just saying it won't be the easiest swap in the world and would need some custom fabiraction. with the centos, to get the engine to fit you need cut and reweld the inner wings. panda engine bay has a bit more room though i think
Old 29-01-2006   #10
Well panda has more room
Now i don't know what to do...if to buy a turbo engine and risk the swap or to get a 1242 engine...
Old 29-01-2006   #11
arc
arc has donated!
or 1242 engine and turbo that..
i dunno how the fueling is handled on pandas, some of them arent EFI are they. i should probably head back to the cento section
Old 29-01-2006   #12
my panda is a 1000 fire 33kw
Well the problem is that a UT engine can be founjd in my town for 300 with gearbox but the 1242 and than turbo the 1242...hm...it would be a very big expense
Old 29-01-2006   #13
It's a bit noisy
FuzzyPanda's Avatar
Trader Rating: 1
Well, if upgrading a 1108 'cento to a 1242 isn't too much trouble, then surely a 1108 (selecta) Panda to a 1242 can't be much harder?
Old 29-01-2006   #14
arc
arc has donated!
Quote Originally Posted by FuzzyPanda
true, but isnt the 1000 FIRE panda a 999cc FIRE unit? And if its running a carb and dizzy then upping that to a 1242 punto engine isnt as easy - it'll need all the electronics to control it - or need setting up to run on the carb i guess.
Old 29-01-2006   #15
Well i think that in the end i'll find a cheap 1242 engine to put it in....i have at home a k21 turbine
Imagine that,complited!
(G) Uno Engine Swaps Chas Uno Uno 53 30-08-2017 21:57
oil - question for GC Hellcat Lets Talk FIAT 47 17-01-2006 13:54
(T) URGENT: Engine Mount Question arc Cinquecento / Seicento 3 31-12-2005 19:26
(T) Multipla engine swap... drnino Multipla 4 21-06-2005 08:53
(T) Engine swap Chris g Cinquecento / Seicento 4 25-01-2004 18:48
