Albert Alfvag
Member
Hello. Albert from Sweden checking in. It's those three months of the year now that I can be outside and get some work done.
So the thing is, I've had some oil seeping out from around the rocker cover gasket for quite a while now. Last year I replaced the gasket thinking it would solv the problem but I don't think it has. I was careful not to over tighten the bolts and so just snugged them down.
I'm starting to wonder if maybe the problem could the the seal on the distributor shaft but I'm not sure.
But I do know that I would like an engine not covered in oil. Any advice would be appreciated and I'll post a picture so you can see the problem.
All the best.
Albert
All the best.
Albert
