![]() | #1 | ||
Posts: 9 Thanks: 0 Trader Rating: 0 ![]() | 1992 Panda Horn Relay? Recommissioning my Panda Selecta & horn not working. Fuse okay but is there a relay as none visible. Connected horn direct across battery but nothing hence relay question. Thanks
![]() | #2 |
Posts: 5,112 Thanks: 300 Trader Rating: 0 ![]() | Re: 1992 Panda Horn Relay? mk2 pandas do not have horn relays, they are directly earthed through the push button in the middle of the steering wheel. they usually have a live going directly to the horn behind the bumper. hold the button down and turn the steering wheel.. maybe the slip ring has a small bit of corrosion on it. you can take the middle button out by undoing the 2 screws on the back of the steering wheel.. give it a brush over and maybe add a dab of copper slip to it. its how i fixed mine.. hope this helps.
__________________ |
![]() | #3 | ||
Posts: 9 Thanks: 0 Trader Rating: 0 ![]() | Re: 1992 Panda Horn Relay? Many thanks I’ll try it out. I’ve checked with a multimeter and there is 12v to the horn so also bought a replacement as well.
![]() | #4 | ||
Posts: 9 Thanks: 0 Trader Rating: 0 ![]() | Re: 1992 Panda Horn Relay? Horn issue continues. Works fine with no ignition on but when on - nothing but a very weak and short beep. Have cleaned both earth hedgehogs by water bottle and o/s front strut but still no improvement. Any thoughts?
![]() | #5 | ||
Posts: 3,991 Thanks: 286 Trader Rating: 0 ![]() | Re: 1992 Panda Horn Relay? Does horn work better?
![]() | #6 | ||
Posts: 9 Thanks: 0 Trader Rating: 0 ![]() | Re: 1992 Panda Horn Relay? All sorted. Further earth cleaning sorted the issue. All good and recommissioning continues - went for a run on Saturday and all good. Full service next and ready for some cosmetics.
![]() | Pfil32 | Ducato | 12 | 23-07-2015 13:07 |
![]() | plumberslinda | Ducato | 2 | 11-09-2014 13:41 |
![]() | Kedishen | Punto (Mk2/2b) | 6 | 26-02-2012 23:31 |
![]() | jacob25119 | 124 Spider (Classic) | 2 | 14-04-2008 04:50 |
![]() | dreamofgilgamesh | Punto (Mk2/2b) | 2 | 12-03-2007 14:19 |
