i ditched the Bosch injection system on my 999 panda 4x4ie cause it was not working and had a rep for unreliability. i fitted a carb and manifold and a electric fuel lift pump as that seemed like a simple way to get the car running. the carb has never let me down but i has never been brilliant either. its spluttery prone to stalling when cold and never had a steady idle. i have 2 carbs and some times i strip and clean the spare and swap it over with disappointing results (i have never splashed out on a rebuild kit that might help) i have also switched between points and electronic ignition with little difference. all this makes me think fuel injection might be a good idea so iam pondering my options which are.
1 find a working marelli injection system.
2 fit a 1.2 mk 1 punto engine
3 fit a mk1 punto injection system to my 999cc engine. what would this involve? i would need throttle body. ecu, engine loom, fuel pump, manifold (would the punto one work or would it be custom) probably i need a crank position sensor in there some where. the old bosch system i think ran of a signal from the ignition coil. has anyone tried this? any thoughts?
