ArchStanton
- Apr 4, 2017
- 4
- 3
My 4x4 has been standing for a couple of years. Now time to recommission.
It was laid up after I changed the head following camshaft seizure. The reason was identified and fixed (blocked oil spray bar), but I encountered a problem on reassembly and had no time to investigate.
The engine starts from cold on the choke and runs at a fast idle. However, any attempt to raise the revs results in hesitation and cut-out. Returning to idle, the engine runs again for around 2 or 3 minutes after which it will die.
The valve timing is correct. I have a new coil, distributor, carb, and fuel pump fitted. Refitting the old components has no effect.
Any ideas folks?
My old coil was marked + and -, whereas my new one has 1 and 15 by the LT terminals. I presume I can ignore these figures and wire the coil in the same orientation as before.
Cheers.
Any ideas folks?
Cheers.
