Technical brake lines
Stockport
I am preparing to get kitted up for making new brake lines. As this is obviously a very safety - critical part of the car I will be doing polkenty of off-car practising first, once I have bought the right tools for the job.
Can anybody advise me - are the flares on the factory fitted brake lines SAE or DIN flares?
Thank you.
pandas use a din flare, on a 3/16 pipe usually use a 10mm union. i was able to do some cracking flares using a cheap ebay kit for £10. its done everything from brake lines to copper fuel lines to even air conditioning pipework as they support loads of different sizes.
just always make sure you slide the union up the pipe before you flare the end!
*like i never did... many times.. sigh*
Here are my tools both bought many years ago:
Both have their limitations. With the first one, which only does brake pipes, despite the fact it has a pin which acts to line things up, you need to be careful to get the two die halves lined up "just so". As long as you do it makes lovely flares. The second one is much easier to use but relies on the long "spindle" to centralize the flare to the end of the pipe. The problem with this is that it sometimes, because it goes so far into the pipe, gets really tight to remove after you've formed the flare. I haven't broken it yet but I'm very conscious that it must be removed without bending which would be liable to snap that wee protuberance off and leave it in the end of the pipe. The first tool has a much shorter "pip" to stop the tube collapsing and you can use the threaded nut to withdraw the punch in a straight line. The biggest limitation though is that pretty much all these cheaper tools will only really deal with copper, or maybe Cunifer (cupro nickel) tubing. Steel is really to hard for them. If I had the money I would but a Sykes Pickavant Flaremaster 2:
https://www.sykes-pickavant.com/products/braking-tools/pipe-flaring-tools/65
In the unlikely event you decided to buy one make sure its a "2" - The first version had a weakness which could cause it to fracture.
Oh yes and like John says above, don't forget to put the tube nuts onto the pipe before flaring. I too have done that more than once! and slide the tube nuts to their relative end of the tube before bending. Wouldn't be the first time I've ended up with a perfectly flared pipe complete with 2 tube nuts at one end and all the bends carefully formed with no chance now of getting one of the nuts to the other end of the pipe! (best not to try straightening and rebending copper - or Cunifer - as they work harden. Ok, you can anneal but better not to need to?)
By the way both my tools are SAE. the difference is in the shape of the back of the flare when compared to a DIN. I find that because the Copper/Cunifer is a soft material it deforms to take up the shape of the nut as you tighten it. I worried at first when DIN started to become the norm that the nut would cut into the back of the flare and cause problems but I've looked at ones I've done previously and then removed later and I don't see any problems. The inner edge of the tube nut is chamfered where it bears on the pipe which helps a lot. Look at the two metric nuts on the right hand side here:
and look at how neatly the back end of the flare sits into the chamfer:
Lovely jubbly and I've never had a problem with leaks or fractures. Been using that first tool since the '70s.
Also make sure it's the correct way around
i never had that issue. pretty much every flare you do on a panda will be a male flare.
really enjoy replacing brake lines. copper/nickel pipe is lovely to work with.
I didn't mean putting the wrong flare on
More placing it the wrong way around e.g having the threaded part facing inward rather then outward
i have found this cheap brake pipe tool works well its called blackline but iam sure its sold under other names too. i previously had an even cheaper flare set that did many sizes very badly before it broke.
I've seen this tool advertised before and it looks very much like a simplified version of the first tool I bought - see above post. The Rally Design advert (where they are advertising it for £6.25) states it's SAE and I see SAE on the die head of your picture. Our Fiats should have a DIN flare but I've used my SAE tools on them for years without any leaks or other problems. That is with Cupro/nickel and copper tubing. Don't think it'll work with steel pipe though.
I agree with John Dragon Man above about replacing metal brake lines being an enjoyable activity - although getting the old unions undone can be a bit of a pain if you are trying to save the likes of flex hoses and/or cylinder/calipers. I like my replacements to be exactly the right length with straight runs and nicely formed radius bends - Got to look neat when fitted. It's quite surprising the number of replaced pipes you see which fall well below the standards I force upon myself. I've seen pipes zig zagged to use up excess length. One actually coiled in a single loop! and pipes which are not even remotely following the required routing or clipped to axles/chassis. How do these aberrations get an MOT pass?
Thank you. Now that we are seeing some signs of warmer weather I will get stuck in to this soon. Looking forward to getting the Panda on the road!
Unfortunately, or fortunately whichever way you look at this, our grown up son is always taking on new projects, like moving in to new business premises which need work doing on them, or his latest one, buying back the body shell of an S13 Nissan which he sold (as a rolling shell about 4 years ago). He has bought it back for nostalgic reasons but it requires quite a bit of welding, which "we" will end up doing! He assures me it will be worth the effort.The poor old Panda ends up at the back of the queue but I am determined to get there.
Thanks for the help :)
Better than being bored
Just for everyone's info. When I was recently in Kenny Harrison's Fiat specialist garage they were renewing a lot of rusty brake pipes on the rear of an MOT failure. The car was up on a wheel free lift and I had a "nose" around it. (I seem to be tolerated in the workshop as long as I'm not getting in anyone's way) The new pipes were being beautifully fitted and He was flaring an end as I watched. The tool and it's box were on his workbench and I'm pretty sure it was one of these:https://www.frost.co.uk/brake-pipe-flaring-tool-set/
Thought it might be interesting to post it here as I see Frost claim it's usable on steel pipe! I think you can buy the Din and/or SAE tools separately which would, I assume, reduce the price if you only needed to do Din flares. Oh, there you go, I just found it:https://www.frost.co.uk/4-75-mm-din-flaring-tool/ Looks remarkably like the £26 tool? but maybe made of better quality materials? I'm only guessing at that because I have bought a couple of things from Frost. They are never "cheap" but the quality of the stuff they sell has never disappointed.
Hi Jock,
When you make your own brake pipes using sae flares do you use new sae flare nuts?
The frost flaring kit looks grand.
Jack
Now that's interesting. you'll notice in the post I made above - 4th post in this thread - that I mention I have some reservations regarding the longevity of the forming die for the second tool because it uses a long extension which locates inside the tubing when forming the flare so as to keep it centralized. I mentioned that sometimes it can be difficult to subsequently remove the die strip due to this extension becoming "pinched" inside the pipe when the flare is formed and it worries me that it would be all too easily snapped off.
Well, I was having a wee browse around the Frost site after making my last post here and guess what they sell? https://www.frost.co.uk/replacement-forming-bar-for-flaring-tool-brake-pipe-tool/ Yes, it's a replacement die strip for my tool! I would guess they wouldn't be doing that if the wee protrusion didn't tend to snap off?
I'm back Jack. You ask if I always use new nuts? Yes, most of the time. Because these are safety critical components but also because they tend to corrode badly in service. I do tend to keep old nuts if they are in very good condition and especially if they are an unusual size but I only use them if pressed to do so, maybe because new stock is unavailable. I just dug out my wee collection of tube nuts:
Unfortunately the only one with it's label still attached gives no indication as to specification. Reflecting on how I buy these things I just walk into the Factors and ask for a packet of metric or imperial tube nuts, male or female as required. Typically this does the trick but just very occasionally I'll find one that's slightly different - often on an ABS unit. I've been messing about with this sort of stuff for long enough now that I find I can look at it and think "Oh, that's slightly different" in which case I just take the old one with me when I go to the Factor. Can't say I ever have any problems doing it this way.
Here's a selection of common connectors for those who may be reading this but not familiar with the subject:
At the bottom there is a metric female on the left and a metric male on the right.
Next up is an in-line connector. This can be useful when connecting replacement tubing into long lengths of pipe - typically front to rear pipes - where perhaps only a small section, often at the rear, is corroded. I don't know if it's a legal requirement but I find MOT inspectors get "twitchy" if you try to use more than one in a pipe run. This actual connector is a female but uou can also buy males if that works better on your particular job (I think the female looks neater?)
Next up is the SAE version of the metric ones at the bottom of the picture. Works just the same but the threads are imperial and you can't really confuse them as they look entirely different - but I've seen people try (sigh).
The top ones are I think from a very old BMC vehicle I worked on many years ago and are just a bigger version of the SAE size mentioned above - to be honest I don't remember much about them. Just chucked tham in here to illustrate that, if you're not observant, it's quite possible to get mixed up. Always try a new nut into the fitting on a dry run before using it just to check it's the correct size and thread.
If you look at the shape of the female nuts in particular the difference is very obvious.
Then there's the DIN vs SAE "problem"? Well take a look at this: http://www.fedhillusa.com/?page=fla...e.&text=If the end of the,it is the DIN flare. The SAE flare is on the left and the DIN on the right. Notice the SAE is chamfered on the back of the flare where the tube nut is going to push against it whereas the DIN is at right angles to the pipe. You would expect therefore that the SAE tube nut bore will be heavily chamfered and the DIN one will be squared off? However have a look at this:
The one on the left is an SAE and the right one is a Metric DIN. See much difference? No, neither do I. Both are slightly chamfered. I've been making flares with both my SAE flaring tools for years on both metric and imperial fittings and never had a problem. I used to worry that if an SAE flare were used with a metric DIN nut that the shoulder on the Metric nut might cut into the taper produced by the SAE flaring tool on the back side of the flare. In practice I've never seen this happen.
So, if we consider the Metric tube nut and the pipe flared using the SAE flaring tool then take a look at this SAE flare made with one of my old tools with a DIN nut:
its a lovely fit isn't it? The end of the pipe is a No2 flare whereas the ones in the link above are No1 flares. Don't let that throw you though as it's the way the flare sits into the nut which is important.
I honestly couldn't tell you how many flares I've done like this and never had a problem at all, No leaks and no pipe fractures, even after years in service. Perhaps it's relevant that I use Cupro Nickel (Kunifer) Pipe on longer runs because it's a lot more rigid than pure copper but I happily use copper for shorter runs, especially if there's a lot of bends to form which are a lot easier to do with soft copper. Beware using pure copper on long runs as it's so soft it will sag. You'll need to fit extra retaining clips which is a pain on some vehicles. Also only bend once! It work hardens so if you bend it and then try to straighten it out again you will weaken it and it may fail in service unless you anneal it (another subject all together) - Sorry Jack, I'm sure you'll know this but I thought I'd put it in for people who may be reading but don't have the experience.
I suppose the official recommendation must be to use a DIN flaring tool with metric fittings and an SAE with Imperial sizes. Up to the individual to make their minds up on this but it would be daft, if you don't yet own a tool, to buy an SAE flaring tool to do DIN flares! Oh, and beware, many of the cheaper tools will only do SAE flares and only on "soft" pipe so copper or, maybe, Cupro Nickel. Definitely not steel which is going to be the original manufacturer fitment. Ok if you are replacing a complete pipe but no good if you are patching into an original front to rear pipe, for instance. If you form the "wrong" flare type for the nut being used (as I sometimes do, ie, using my SAE tools to flare pipe being used with metric nuts) then you'll need to be prepared to take responsibility, as I do, if it all goes wrong! So, if you are inexperienced and not too sure what you're doing don't risk it. The outcome could be lethal!
Well, sorry if a lot of that was stuff you already know Jack - I'm sure a lot of it was - but I thought it might interest others?
Hi Jock,
Thank you for a lovely write up about what you have discovered "in real life".
Very helpful because I was concerned about using sae flares with din nuts-now I am not.
I had a feeling sae flare nuts are fully threaded and din partially threaded this is not correct you have to check visually.
Thanks again
Jack
Hi Jock,
Jack
Hmm. I'm just reconsidering your question here Jack and wondering if I got hold of the right end of the stick.
You asked if I use new SAE tube nuts when making new SAE flares.
Well, my "problem" - which has turned out not to really be a problem - is that both my tools produce SAE flares so I have no option to make DIN flares. - I'm very attracted to that DIN tool Frost are doing for 30 something quid though.
Your question sounds a bit "horse before cart" if I can say so without giving offence. So, yes, If I'm making an SAE flare and the tube nut required is an SAE (imperial) thread then I will be using new nuts wherever possible (which is pretty much always. However I may be making an SAE flare on a pipe which I'm going to be using a Metric Tube nut with (which Ideally I probably shouldn't be doing, but it works for me for the reasons in my above earlier post) and I would, in this situation, be using a new metric nut. In other words I will always use a new nut if I can get one and would only consider using a second hand nut if a new one is not obtainable and I had a used one which was in very good condition.
I'm not quite sure if that's the answer you were looking for? If not please do rephrase and ask again.
