matthewnum14
- May 31, 2015
- 35
- 14
mk1 punto 55 (up to year 2001)
any Cinquecento sporting
... pretty much any Fiat up to about 2001. after that they went fly by wire and have a knock sensor in the cam cover. though i dont think the block or cylinder head changed. so if you wanted to keep carbed the original 999cc manifold would bolt on any 1108cc engine no matter how new or old it was
to keep it standard you'd need to swap in crankshaft and rods,
The rods are the same, its the crank and the pistons that you need to swap. The gudgen pin holes are closer to the piston crown on the 1108.
