Hope someone can spare my blushes & give me a couple of pointers on changing the top engine mount (gearbox side) on a Fire 1000ie. I did the driver side ok & have disconnected the mount on the passenger/gearbox side but can't pull the mount off the captive bolt because of brake pipes, master cylinder & general stuff in the way. What is the easiest way to do it...do I need to unbolt the brackets on top of the gearbox to free the captive bolt & so hopefully give me clearance to remove the mount....or do I need to take off other bits (washer bottle) to give more room? Haynes/Parkers say remove the mount but no more clues! The captive bolt which goes through the centre of the mount seems a variation of ePer illustration which I think shows the bolt the other way round, on mine there is a nut to unscrew leaving the bolt still in the mount. The other possibility is jacking up the car to raise the car body off the gearbox...but am worried about a stressing joints? Any pointers welcome
