I could use a bit of advice: I want to transplant an 1.2 8v engine in my '87 carbed Panda. I need to get sufficient fuel to the engine.
If I swap the tank for one out of a 1.1 model, would that fuel pump be sufficient to feed the 75 engine? I believe they are 3 bar @ 70l/hr? What to do with the fuel return line? I think the Punto engine needs a return line, but the Panda doesn't have that provision, does it?
Following up on that: If I swap out the pump for one out of a Punto, do I need to change out just the little pump, or does the entire Punto unit fit the Panda tank?
