I just bought a complete engine out of a Punto 75. It came complete with ECU, wiring harness, code box, key and aerial, and a big box of other wiring and bits and pieces I'll have to sort through.
The engine is going into my '87 Panda 1000. Will I run into any issues swapping the carbed Panda engine for the fuel injected Punto block? It looks like I've got all the bits to make it work - minus the new fuel pump, which will be on its way shortly. Just want to make sure I don't run into any nasty surprises mid-swap!
The engine came without exhaust header. I could reuse the Panda header, but I've also found a 16v header for cheap - is there any benefit of using that instead?
