Sjvarley
Established member
- Oct 18, 2016
- 827
- 212
got my eyes on this too,unassisted brake lifethis is awesome work.. any need to run an extra brake line to the rear? got any pictures? very tempted..
Note the front and rear outlets are transposed. Tee fitted to split front feeds.
as a lowly pandaneer. I believe it does as the master cylinders. Are not linked by a mechanical means. Fluid chamber. So the larger rear chamber created pressure when the front brakes. Start to resist the flow. The second chamber moves push ing the drums. This prevents the rearsxel sluing out. But it could also the rear restriction valve holds off the pressure until the front is resisting flow. I think.
Forgive a stupid question - ..Does it matter which chamber pumps to which end of the car?
Is there a how-to guide on fitting rear discs?
