Old 12-07-2018   #1
Propshaft CV joint separating
A quick question for you 4x4 experts. I'm in the process of replacing the 2 CV joints at the front of the propshaft but the rear one won't separate. Hopefully the attached pic will explain. Any ideas how to separate them? I've tried a gear puller but there's not enough purchase on the inner lip. Thanks, Chris.
'86 Panda 4x4
Jammytask is offline Reply With Quote Quote
Old 12-07-2018   #2
Re: Propshaft CV joint separating
2nd pic hopefully explains the issue.
'86 Panda 4x4
Old 12-07-2018   #3
panda1408 has donated!
A few taps to the side of the CV joint should be enough to free the two parts. Which the shaft fully assembled you can add some tension by pulling the front section away as you hit.
I have taken apart quite a few and have never needed to resort to any sort of puller or press to remove the CV joints. Also I hope you have marked all the components in relation to each other otherwise you will need to have it rebalanced when it is reassembled.
Likes Sjvarley liked this post
1988 Panda 4x4 Sisley
1982 Panda 45
panda1408 is offline Reply With Quote Quote
Old 13-07-2018   #4
Thanks for the reply, the rest has come apart perfectly but this part is putting up a fight, I'll grab a bigger hammer then....
Yes it's all marked for balance.
'86 Panda 4x4
Old 14-07-2018   #5
I Void Warranties
Dragon Man's Avatar
Dragon Man has donated!
i had the same issue.. thankfully i have a good vice with wide opening jaws so i grabbed the CV joint in that then used a blunt chisel to knock the rubber cap bit off.
Likes lukmek, Jammytask liked this post
Dragon Man is offline Reply With Quote Quote
Old 16-07-2018   #6
Quote Originally Posted by Dragon Man View Post
Cheers for the reply, I'll give that a try, it's certainly not budging with a 'few taps'.
'86 Panda 4x4
Old 24-07-2018   #7
Dragon Man, your chisel suggestion worked a treat, fully rebuilt, new CV's and rebuilt UJ's and a lick of paint, thanks for your help folks.
Likes Dragon Man liked this post
'86 Panda 4x4
(T) Propshaft vibration Velociraptor 4x4 Panda 3 10-05-2018 07:16
(T) Propshaft Question northernchap Panda (Classic) 12 15-07-2016 20:54
(T) Propshaft Leak panda1408 Panda (Classic) 9 18-08-2013 20:20
(T) Propshaft servicing. Trusham Panda (Classic) 9 19-03-2009 08:25
(T) separating gear box from engine? Bushboy Cinquecento / Seicento 28 06-04-2005 23:30
