Technical Wanted: Door drop glass : Panda 82-95
gsxrtam
I am looking for a door drop glass for the following :
Fiat panda 3dr . 1982-95
Seat Marbella 3dr . 1989-95
Seat Terra van . 1990-95
I'm not a Panda expert, and am unsure if the drop glass fitted to early cars that also had a 1/4 glass is the same for later cars that didn't have the 1/4 ?
But I do know the doors are all the same physical shape and size, so even if the later glass is larger, it will still fit . . Although the rubbers, guides and maybe the regulator might be different, but I'll modify them if necessary.
I'm also pretty sure that because the glass is flat, they are not sided Left and Right, and the runner attachment does not have fixed brackets on the glass but is an old style rubber strip, with the glass compressed into the regulator.
Its needed for a 94 Terra van drivers door that has the 1/4 in it.
Any suggestions ; Breakers yards contact info or members who can help would be much appreciated . .I'd prefer to get one in the UK (Scotland is even better !) for the simple reason that glass does not travel well in Couriers vans !
Seans.Bike.Shop. Edinburgh
Try to post on “panda parts request” thread
I will try and get 1 from you, probably from Italy
