Thread Tools
Old 08-02-2018   #1
Malta
Carburetor mixture screw adjustment
Hi all,
Im trying to adjust the mixture screw in my 1000 fire panda and cant seem to get it right. The engine misfires on rapid acceleration and is idling rough. The carburetor has been dismantled and had new gaskets and all the jets cleaned out thats why it lost the setting. What is the best way to adjust the screw?
Thanks a-lot
turbo93 is offline Reply With Quote Quote
Old 08-02-2018   #2
Re: Carburetor mixture screw adjustment
Also be sure itís firing correctly first it may also be the auto advance
Sjvarley is offline Reply With Quote Quote
Old 08-02-2018   #3
Malta
Quote Originally Posted by Sjvarley View Post
What do you mean?
Likes Sjvarley liked this post
Old 08-02-2018   #4
Quote Originally Posted by turbo93 View Post
Hi all,
Thanks a-lot
Screw in mixture screw till it stops, screw back out one and a half to two turns, run engine to temperature, turn screw in until misfire/judder/engine note changes, turn out until the same happens, turn back in until engine runs smooth. Although suspect not the issue your having.
Mal.
Mal126 is offline Reply With Quote Quote
Old 08-02-2018   #5
Malta
Quote Originally Posted by Mal126 View Post
Mal.
Ill try this. What do you think it could be if not it? Leads and plugs are new. Car has sat for roughly 5 years. But its not the first time i started it in the past weeks.
Thanks Sjvarley thanked for this post
Old 09-02-2018   #6
PANDA!!
Freebo's Avatar
Freebo is part of the official FF Events Team :)
Freebo has donated!
Ghost Ball Champion
Could be the vacuum advance, take the rubber pipe connecting it to the back of the carb at the carb side. Try sucking on the pipe, there should be a lot of resistance, if there is not then you'll need a new vacuum advance or may have a split in the pipe.
Freebo is offline Reply With Quote Quote
Old 09-02-2018   #7
Malta
Quote Originally Posted by Freebo View Post
So it does that big of a difference? Ill try it though. Thanks alot?
Old 12-02-2018   #8
PANDA!!
Freebo's Avatar
Freebo has donated!
Ghost Ball Champion
Assuming its been tuned with a working on then yes, If I pull the pipe off my vac advance on the 4x4 it kills the engine (or did last time I did it).
Old 12-02-2018   #9
Malta
I did this and it only made it worse so im assuming its not this.
Old 12-02-2018   #10
PANDA!!
Freebo's Avatar
Freebo has donated!
Ghost Ball Champion
Ok, worth ruling out I guess.
Old 12-02-2018   #11
Malta
Could it be that the points inside the distributor are corroded?
Old 12-02-2018   #12
PANDA!!
Freebo's Avatar
Freebo has donated!
Ghost Ball Champion
It's worth checking everything you can.
Likes turbo93 liked this post
Thread Tools
(T) Carb Fuel Mixture Screw Help please? onemanmade Panda (Classic) 11 26-05-2017 22:11
(T) 750 CLX fuel mixture screw m0rg Panda (Classic) 3 20-03-2017 12:15
(T) Lost Screw (idle adjustment screw) ReKone 500 (Classic) 5 13-02-2017 14:06
(T) Mixture Screw JakeF 500 (Classic) 9 21-03-2013 16:16
(T) Co / mixture adjustment paulo arrigoni Panda (Classic) 6 11-02-2010 21:09
