General Panda colours
turbo93
Member
Hi all! Is there anyone who has the color chart of the classic pandas?
Thanks [emoji4]
For which year?
They were usually in the back of the brochure - several of these are scanned into this section, so maybe you’ve already got the ones you need?
Where can i find one? Mine is blue from 1989
Your colour is either in the rear tail gate or wheel arch printed on silver foil with the code. If that’s what your after,
Yes i know but the tailgate was changed by someone else and so was the sticker of the colour code.
If you struggle to identifying the colour. Most refinishing supplier will do a test match so take a door to them and they will use a spectrum
Analyser mix a small test pot worth it if your after the inside to outside perfect match paint can then be put in rattle cans or pot mixed 2 k paint is the best
This is her. But she has been overpainted in a disgusting manner as there are dropplets everywhere. Ill post a pic of the inside colour as its the factory original.
I found this beautiful panda apparently owned by someone is japan. Whats the colour on this one? IMG_0408.JPG
What are you asking then? You asked which colour your Panda was and posted a photo..... We’re trying to help, but you’re not making it easy! :rolleyes: :confused:
I know youre right. I posted a photo of another panda above my post and thats the original colour of mine. Thats the code im after. Thanks a million :)
The correct code for a mk2 1989 Panda is 402. (y)
The other picture is an earlier mk1 Panda and won’t be the same. It’s the colour of my mk1, but the car is a couple of hundred miles away & I can’t check the code. If I remember correctly it’s helpfully labelled “blue”!
Sorry, I thought it was 402 as well! Apologies. This website has a comparison and the blue looks really similar to me, but reckon it’s just a trick of the light in some of the photos
http://auto****e.com/topic/11045-fiat-panda-spot-the-differences/
