Hey guys!
some of you know that a while back i had a Seat Marbella. it has outstanding brakes. it used a vacuum assisted master cylinder that had 4 pipes coming out of it.
now i have 2x panda 4x4s with rubbish brakes. they both use a vacuum assisted master cylinder with 3 pipes coming out of it.
im looking for help here as i have forgotten how the brake system on the Seat Marbella works. on the panda with 3 pipes, 2x of the pipes go to the front wheels and one goes to the rear though a valve thingy just under the master cylinder then to the rear brakes.
does the Marbella have the same valve, or do the pipes coming out of the master cylinder go directly to the wheels?
my plan is to convert a panda to use the marbellas 4 pipe master cylinder by running an extra pipe to the rear wheels.
i have tried everything i can think of to get rid of the super spongy brakes i have at the moment (the whole braking system on Fallout is brand new!) but sadly the brakes are still spongy.. on both 4x4s!
could anyone with a marbella post a picture of the servo assisted master cylinder? i need to make sure the bolt holes are in the correct place.
the best of it is, even if this does not work i would have only spent like £30 on parts! man i love pandas. though i keep saying it.. i really wish we never sold the marbella.
Thanks all, you're the best-ist!
