Hi All
I have recently purchased 750 CL in need of some work
after replacing suspension and getting the car running apart from a leak from around the water pump I seems to be nearly close to getting it back on the road. though I have one issue that I am stuck on and require some help
the issue is that firstly the break reservoir has a hole in it
As well as it not fitting the master cylinder properly, from what it looks like the previous owner swapped the master cylinder for the 4x4 version guessing because it was cheaper
so I need to find ether the correct master cylinder and reservoir
or a bottle that would fit the 4x4 master cylinder both of which I am struggling to find
