Thread Tools
Old 23-09-2018   #226
Re: Just started and could do with some 4x4 help.
So back to the previous work and we are up to the end of August.
Popped the wheels on for a few images .
Then on to other stuff.
A shot for Andy to comment on?
Handbrake cable laid in well.
Clean up and the master cylinder and servo with a new site of custom hoses from furoreproducts.co.uk.
And a new site of tube work lifted from a Land Rover kit for £11!
Good friend Mel came round to assist with the brake lines. Used to work on Land Rovers which helps apparently.
Servo looked better? Even better when I put it the right way up!
New Pin
Right way up.
Rear tube-work done.
Hoses in.
I will not need a jack to work underneath this Panda!
Few steampumk twists.
Painted and trimmed callipers done.
Exhaust and radiator now delivered.
More soon.
Likes AndyPanda4x4 liked this post
Derek C is offline Reply With Quote Quote
Old 23-09-2018   #227
Right up to date now. With the weather that took out the paintwork still ongoing retreated to the garage for some work on the propshaft.
New hex caps for the bearings.
Straps fabricated for the bearing supports.
Few bolts and all looking neat.
Few touch up brushes of paint and ready for refit.
Now a bit of an impulse buy I set about fitting the K&N filter for the Weber. Now its not a factory fit for this carb. Needs an extra hole.
Used some 5mm brass threaded bar for the support after removing the original bracket.
UK K&N Ref for the 32 model carb.
Drill extra 7mm hole for the correct location.
Couple of short bolts with lock nuts to cover the holes we wont use.
Bit of cutting back to look smarter but it all fits OK
Ready to fit. Probably going to need to go up a jet size and fit a foam surround for puddle hopping days.
More later.
Thanks for looking.
Likes Dragon Man liked this post
Old 24-09-2018   #228
Brilliant stuff D C. Concise. And detailed record. Great work would love to see this. Perfect panda. Ps. I am on the road with the Panda 4x4 GT 100
sorry for the thread hijack
Sjvarley is offline Reply With Quote Quote
Old 24-09-2018   #229
Steve you can hijack this thread anytime!
Two twins from different dads?
Neat
Likes Sjvarley, Michael Dranfield liked this post
Old 24-09-2018   #230
Cheers. Let’s have you sorting green lanes out around your way.
Old 16-11-2018   #231
So yet another apology for failure to progress.
Work is pretty manic and I guess its all linked that to leaving Europe thing.
I did also take busman’s holiday to Tuscany and photograph a few Panda 4x4s and other stuff.
Its now a year since I started stripping the Panda so I thoughts I’d better get some in.
Managed to get an exhaust off Eurocarparts for less than £60 and it came with this which was not needed as the twin downtube original has a domed section.
Went in OK but new hangers required.
Questionable but ‘rugged’ welding.
All looks a bit close to the rotating parts but I am still on the jacks.
Manifold had a clean up and coat of high temp paint. New gaskets fitted.
Same for the downtubes and bracket.
Especially the end section. Not too worried as I have plans for the tail pipe
Carb and stuff all fitted.
Started feeding the front loom through. Worst part will be connecting the wiring and I am just a little bit really colour blind!
Fuse box cleaned and buzzed out. All looks good.
Spaghetti Junction!
Picked up a loom for cable salvage lots of colours and protective tube stuff.
I plan to hide as much of the engine bay cable as possible for a clean bay look so will be extending lots and of course more lights to go on!.
Colour match spray job on the ‘environmental control’ box
Start the engine wiring next week and then pop some petrol in.
More soon.
Likes Dragon Man, andyholli liked this post
Old 18-11-2018   #232
I Void Warranties
Dragon Man's Avatar
Dragon Man has donated!
Fantastic work!
such a nice colour!
just keep spraying the air filter oil over the air filter.. make sure its filtering the air good. just a personal opinion but i am not a fan of "high flow" air filters. if you ever send oil off to be analysed, they can always tell you have one on due to dust and silica in the oil.
even fallout has the original paper filter still in it, even though i have that silly cone air filter on the end of the snorkel (which is more for preventing people posting crisp packets and other litter down the air intake...)
Thanks Derek C thanked for this post
Dragon Man is offline Reply With Quote Quote
Old 18-11-2018   #233
I word. Quality.
Old 2 Weeks Ago   #234
Well obviously been away far too long. Was working on the Panda up until Christmas then ran away to Oz for several weeks. Work took over and the weather didn't support any real progress plus some family stuff good and bad. Life is the thing that gets in the way of plans they say.
First the missing pics as the directory got screwed..
Right the updates will take some time but news flash My Monster Lives! well it runs anyway.
More coming.
Old 2 Weeks Ago   #235
So the up-rated alternator took up a lot of space.
There are two screw terminals here and the old one had a tag terminal for the 'monitor line'
Thinking I might need to be able to convert back I added a female tag terminal to a screw terminal tag then started the wiring back in. Don't mind the temporary tape on the textile outer.
Dropped a breather on.
New vacuum actuator as the old one failed the suck test.
Tied up the final alternator and starter motor cables.
Then added the volts supply!
Quick set up to see if my hand built motor starts.
Breather from a pit bike added.
Tied all the loose wires.
Then add fuel.
Well sucked the fuel through but took about 20 turns to get the fuel in and carb full.
Then cough splutter and runs!
Short test run as no cooling but starts first pull repeatedly so very happy!
More later.
Old 2 Weeks Ago   #236
Getting It All Back Together
So some indoor time on the lights.
The rears were all in one piece but needed some love.
First strip them down and release 30 odd years of dust.
Thumb clips still in good order as are the seals.
Bulbs out. All corroded so bin ready.
Got a wire brush on the terminals.
Used the small rotary and a light metal polish to clean up the marks an scratches.
Got a shine on!
Finished with a coat of Trim Gel.
Looking almost new?
Mounted with new screws and a new bolt for the earth (more about earths later unfortunately).
Done that end.
Now the headlamps.
Few before pics.
Now a real secret...
Removed the bulbs and pop'd them in the dish washer on short cycle.
Quick lens polish with windscreen scratch remover and hey.
More to follow here as I plan a set of LED bulbs.
Interim front end pic.
Tried to dishwash the indicator lenses but the muck wasn't coming out of the crevices so it cotton bud time.
Dish washer trick worked on the washer bottle and side indicator lenses.
Shoved a slightly more impressive horn into the build.
Finally recovered the number plate lights.
More for the dishwasher?
More later
Old 1 Week Ago   #237
Re: Getting It All Back Together
So the cooling system was next managed to remember where I kept these supports.
Did a clean up on the brackets.
New radiator ebay bargain. Old one still usable but tatty and in the spares stock.
New set of hoses to match.
Last moment remember to swap out the sensor.
Nicely placed and the new badges added.
Now the fan which needed some work.
Quick functional test and all within limits (it works).
Strip down time.
Loving these clean up wipes.
Quick paint and shine up.
Back in place with all new fixings
Fill and test run time.
Fan and temp gauge all worked and new thermostat did as required.
Timing set up. Slightly annoying to get the hose off image rather unstable? Yes I did remove and seal off the vacuum line. Anyone got a view. Vacuum advance on much more stable. Weirdness?
Quick torque up on the now warmed up head. Just a final check.
Tidy bay?
More soon of course.
Old 3 Days Ago   #238
Needing to make space in the garage and empty the spare rooms of parts decided to fit some of the larger parts back on the Panda.
The wheel arch inners had a good clean with 50% APC 50% hot water and a lot of tar remover.
Quick before and afters.
Cambelt cover needed a soak in tar remover.
Covers fitted loose as I have some cables to run in.
Anyone know if I should have a cover over the gearbox end similar to the cam belt one?
Also fitted a new bonnet pull cable. Had to get creative as the original was a sliding clamp and the Ricambio replacement was a bolt on end.
Bumpers had a 50/50 APC, tar remover and then a light sand on any dinks.
Before
After a coat of plastic primer and then afew coats of satin black.
I might have to go back and fill the number plate screw holes depending on the shape of the plates I may use.
Next the engine bay sound proofing. Thought about binning it as two tears but decided as I have lost all the proofing and insulation in the bay it was needed but wants a bit of improvement.
Good clean first.
Then went all Yank hot rod.
Interior update next time...
Thread Tools
Getting started................................ madisonswift Newbie Central 4 17-11-2014 14:18
How to I get started? Simmy101 Newbie Central 2 14-09-2013 12:36
(G) Oh OH, it's started. anc Cinquecento / Seicento 0 27-04-2013 17:23
Punto (Mk2/2b) just started :) doofelx Newbie Central 6 10-06-2012 20:30
(G) I've started Stuartl Panda (Classic) 13 13-11-2007 14:20
