Just measured our rear diff with Freddy
Panda Brian 9"
Toyota Land Cruiser 10.5 "
Freddy's landie 9.5"
Honda CR-V IRS 12"
Just need some more articulation is needed
Trailing arms ??
I'll have to re-measure my Land Rover!
Looking good so far, are you going to do anything with regards to the rear wheel arches? I fear those tyres (like mine and others) will shred themselves on the front of the rear wheel arches.
Heres what happened to mine:
I found in normal road conditions there was no problems but after some offroading at full articulation it makes contact. In wales it also smashed off the wheel arch lining.
We have lifted the body up 90mm and moved the rear axel back by 30 mm although the wheels are now 14" and 195 80 tyres from our calculations it will miss by 15 mm as the Tavel is 160mm up to the bump stop our diff height is now 10" from 6.5 " wheel base is also increased by 50 mm pushing the front track forward by 20mm
Will need stops fitting to the steering travel the width track is also increased by 30mm to enable full drive shaft clearance when wheels are fully unweighted
Steve
But let's see off road trials next weekend might brake something !
Look fab great work guys!!
...sorry but I hate the grill.
No don't throw it away it's the signature of your car! And presumably you guys like it? It's all good. It doesn't matter about my opinion, but I always appreciate negatives and positives and I also like to be honestOk well take it off and throw it away then ! Or would it look better in metallic Rosso ??
