FIAT Auto Specialist Team
Thread Tools
Old 20-02-2017   #1
Wheel arch problem
Fizzy panda 2wd, has a problem with her rear wheel arches, first it was the o/s/r that started going rusty. Then it spread to the n/s/r arch, it only seems to have affected the outer rim section ?, and not the inner underneath part.
Not sure what has caused this, apart from not washing and cleaning salt off, the arches have gradually deteriorated over the last 2 years.
I realize rust and pandas go together, so I guess this is another common panda problem. I would have bought some plastic wheel arches, but they don't seem to have been made for panda.
Has anyone got any ideas as to the best 'cure', chopping up arches from front wings, any other solutions, as trying to prevent this getting worse and make fizzy look presentable..as she is my everyday car, so wanting to give her some TLC.
Thanks Fizzy
(Haven't logged on, so a long time, had forgotten password)
Fozzybear is offline Reply With Quote Quote
Old 20-02-2017   #2
Re: Wheel arch problem
Ok most possibly it water ingress from
The rear window seals at the joint . it can rust at the joint penetrating the body work then water can run. Between the section Rusting outwards. Action cut rust and replace with new steel or repair section treat innner arch with waxoyl or similar
Sjvarley is offline Reply With Quote Quote
Old 22-02-2017   #3
I had the same problem on my parade but only on one side luckily. After a long search I ended up finding and cutting some off a spares panda which were welded on then repainted.
I also know of one that was craftily fixed with filler and you couldn't tell the different after a splash of paint
Jemima the Parade '93 Clyde the Fizz '94
chugbi is offline Reply With Quote Quote
Thread Tools
(G) Inner Wheel Arch atnewton Grande Punto 7 17-07-2016 21:28
(T) Front wheel arch line -splash guard- problem vitaqo Bravo 2 31-10-2014 12:01
(T) inner wheel arch zombie11 Grande Punto 16 27-05-2011 12:35
(T) WTF! Goo inside my wheel / wheel arch ChrisUK Punto (Mk2/2b) 9 12-07-2009 01:20
(G) Wheel Arch Problem! projectpunto Punto (Mk2/2b) 6 12-01-2007 15:31
