FIAT Auto Specialist Team
Thread Tools
Old 02-07-2016   #1
binhoker has donated!
panda 4x4 LHD to RHD conversion
i have a LHD 4x4 and a RHD front wheel drive donor panda i am wondering about the possibility of converting the 4x4 to RHD i can see 2 problems.
The LHD has brake servo that wont fit behind the engine in a RHD configuration. do i need the servo? i asume RHD pandas dont need it. maybe they use different brake calipers.
As fiat designed the car to be RHD the LHD version is an afterthought for this reson i think it is easier to convert a RHD to LHD than visa versa.
I have not explored the fuse box and wiring changes but if i was going to take the engine out, as i may to replace the clutch, then it dose not seam hard to make a few holes in the bulk head and fit the pedals and steering rack to the other side.
Any one tried this? any complications i have overlooked?
I suspect the sensible answer is don't bother. but don't sensible people drive ford Mondeos.
binhoker is offline Reply With Quote Quote
Old 02-07-2016   #2
Rollin' On Steelies
AndyPanda4x4's Avatar
Trader Rating: 1
AndyPanda4x4 has donated!
Re: panda 4x4 LHD to RHD conversion
From looking at the differences between my RHD and LHD 4x4s recently I'd say the simplest way to do it is to swap the whole bulk head over from the RHD vehicle. All of the pedal box mounting, spaces for the heater controls, steering rack mounts, steering column holes, brake servo mountings etc. are all specific to the position of the driver. You could start cutting out holes and mountings in the LHD bulkhead but I think you'd have a struggle to get everything sitting right due to the curves and linings in the steel. If you are a competent welder it would be quicker and simpler to swap the whole section.
But there is the other question, the money saver; is it really worth all the work to have a RHD car?
Edit: I drive a Ford Mondeo.
Likes panda panda liked this post
Fiat Panda 4x4 - What the Yorkshire Dales were made for.
AndyPanda4x4 is offline Reply With Quote Quote
Old 02-07-2016   #3
panda1408 has donated!
As Andy has said the biggest issue is that the bulkhead is not symmetrical in either a LHD or RHD car, each have their own specific panel which means the necessary pressings that allow the components to fit correctly are not there. It is unfortunately not as easy as drilling a few holes and bolting everything in.
It would be a case of cutting the required parts out of a RHD bulkhead and welding them into the LHD car, not a small job, the fabrication of a jig to accurately align the panel would be required in my opinion.
RHD cars with a servo have them mounted in the same place as a LHD with a bar running along the inside of the car from the pedal to the servo. Non servo RHD did have the master cylinder mounted behind the engine so you could use that setup if needed.
1988 Panda 4x4 Sisley
1982 Panda 45
panda1408 is offline Reply With Quote Quote
Old 02-07-2016   #4
Alixcompo has donated!
I've done it and don't recall any real problems. The servo stays where it is with a cross rod from the rhd pedal box. Simples
Alixcompo is offline Reply With Quote Quote
Old 02-07-2016   #5
Quote Originally Posted by Alixcompo View Post
How did you deal with differences in the shape of the bulkhead?
1982 Panda 45
Old 03-07-2016   #6
Thanks for you opinions, Modeo drivers or not. my RHD car has a blanked off cut-out in the bulkhead. I had supposed that was for the brake cylinder if the car was built LHD. It must be where the servo goes, if I had one. I donít but will have to source one if I go ahead with this conversion. i do have a bulkhead and a MIG welder though.
Old 03-07-2016   #7
Quote Originally Posted by panda1408 View Post
If you search 'SEAT Panda Terra' on this forum it shows the whole build including changing 903cc to FIRE engine, MK1 to MK2 seats and left to right hand drive
Page 12 is the dash
Old 04-07-2016   #8
lots of good reading there alixcompo. thanks for the pointer some times its a bit difficult to find the right info on this forum via the search. Did you say you had experience registering an imported vehicle? perhaps i am going about this project the wrong way and i should be converting my 2wd uk registered panda to 4x4 instead or converting a an imported car which I have no paperwork for to RHD.
Old 04-07-2016   #9
It's much easier to convert 2wd to 4x4 than convert left to right hand drive when you already have a registration.
Did I mention the Panda Terra is 4x4?
Old 04-07-2016   #10
so i have only recently become a panda owner but i have worked on one before i moved the drivers position and installed a new power plant. i am the one acting as a counter weight at the back.
Thanks Pandani thanked for this post
Likes Pandani, Alixcompo liked this post
Old 05-07-2016   #11
I Void Warranties
Dragon Man's Avatar
Dragon Man has donated!
well.. thats something.. hell i'd be paid minimum wage to be a counter weight. i think i'd be good at that!
Dragon Man is offline Reply With Quote Quote
Old 29-08-2016   #12
very litle progress with my pandas due to hectic summer schedule but i did buy a new ignition advance servo. and remove the fuel tank from the 4x4 it was badly rusted and the pump is seized. Today i mucked out the carb on the panda lipstick so i got the engine runing on petrol for the first time couldnt drive any where cause i only have 2 wheels and the gear stick linkage is broken. clutch seems to work but engine wouldnít idle striped of intake manafold and fited carb to 4x4 ie after a lot of messing i get it runing but it wont idle, tends to run flat out or stall, only runs for about 30 seconds be fore stopping, and backfires. think next i will try to run the engine with the simper (carb) ignition coil and points
looked at the feasibility of converting the lipstick to 4x4 and i am reminded that its a mk2 and doesnít have rear leaf springs.
think i will have to have a conversation with the dva.
Old 30-08-2016   #13
AKA CLS
panda panda's Avatar
Trader Rating: 1
panda panda has donated!
Is the LHD a 1.1i.e?
Surprising how much difference that set up makes on power compared to the 999cc set up.
My ex-selecta can get up hills in a higher gear and doesn't get bogged down, whereas all the 999cc's do.
How many Pandas is too many Pandas?
Five according to Calderdale council.
panda panda is offline Reply With Quote Quote
Old 30-08-2016   #14
i havenít summoned up the courage to ring the dva yet but i did strip and set my points and fit them to the 4x4 ie. the engine dose not run any better but the process did remind me of motor bikes in my youth. it seems most people like to use the ecu ignition and not points even when they do fit a carb. the engine runs for a few seconds then stops i have decided the problem is fuel starvation so will have to strip the carb again, i am not using a fuel pump just gravity feeding the carb of an old lawnmower tank.
i think the lhd is a 999 ie but i know very little about the cars history would the difference be obvious
Old 30-08-2016   #15
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Quote Originally Posted by binhoker View Post
Nope, the RHD bulkhead is different to the LHD, what you're looking at is the blank for the master cylinder, which will be NS if it has a servo or OS if not.
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Panda Eleganza & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Thread Tools
(T) Ulysse 2: Headlights RHD to LHD Conversion. Mr Sheen Ulysse 0 14-08-2014 13:58
(G) Rhd / Lhd headlight conversion roymck Barchetta 8 14-08-2012 14:55
(T) rhd to lhd light conversion Casasoleen Doblo 4 06-06-2012 15:04
(T) RHD to LHD conversion... Kirkers X1/9 7 27-12-2009 00:51
(T) LHD to RHD Conversion X 1/9 1300 Kirkers X1/9 0 27-04-2009 15:27
