Old 18-11-2016   #31
binhoker has donated!
Re: panda 4x4 LHD to RHD conversion
yea Andy that would be great, i reckon i wont need the servo as i have one in the lhd car. Dont think there would be many in Italy Kolza what with the driver being on the same side as the servo.
Likes kolza liked this post
binhoker is offline Reply With Quote Quote
Old 19-11-2016   #32
balls cant upload photos?
dont know why?
i have uploaded pictures of my bulkhead here at botom of the page. http://www.paddybloomer.com/some-pic...-trailers.html
Old 19-11-2016   #33
ok so heres the pictures properly
this the bulk head from the inside it needs new cutouts and dents on the right hand side for dash steering colum and heater controls and loom and the old ones blocked. need to add reinforcement where steering colum bolts on
on the engine side the the steering rack mounts are in the right place. there is some corrugations that hopefully wont get in the way of the steering shaft. the oval hole will be blocked with the back plate off the old steering box which will provide the correct mounts from the master cylinder
it may not be worth the hassle but, as my lhd steering rack was in need of replacement and i only had a rhd one this car will be rhd. i will swap the wiring loom, the dash, heater. pedal box and clutch cable. i will reuse the steering column, brake servo throttle cable. as i am fitting a carb i will get rid of the ecu, spi manifold, (have to drill hole in carb manifold for servo) and a strange tank under the wing, what is that? and some wires and solenoids.
i will add an electric fuel pump and a choke cable. but first iam gona tip the car on its side and fix a few rust patches and check over the back running gear.
Old 20-11-2016   #34
What happens next
Old 21-11-2016   #35
Rollin' On Steelies
AndyPanda4x4's Avatar
Trader Rating: 1
AndyPanda4x4 has donated!
ID:	173686Click image for larger version
RHD setup
Fiat Panda 4x4 - What the Yorkshire Dales were made for.
AndyPanda4x4 is offline Reply With Quote Quote
Old 21-11-2016   #36
without the engine it was easy to roll over and balances with most of the weight on the wheels and sill. nice one Andy are those go faster pedal rubbers i see.
Old 22-11-2016   #37
Rollin' On Steelies
Trader Rating: 1
Yes they came with my old car when I got it, they add an extra 5bhp EACH!
Likes werdna liked this post
Old 23-11-2016   #38
my new pedal box arrived today. thank you Andy. in the mean time i have been power washing my underside so more panda tipping.
Likes Pandani, AndyPanda4x4, FDNY21 liked this post
Old 24-11-2016   #39
Rollin' On Steelies
Trader Rating: 1
Wow you've done that a few times I'd say!
Old 24-11-2016   #40
Panda Wanda
kolza's Avatar
Trader Rating: 1
kolza has donated!
Can I can you small favour?
Could you have a look around the bulkhead lower wall and access feasibility or removing the lower panel by driling out spot welds etc? Basically how hard would that be to tranplant whole panel.
Sisley '89
Formula '91
W123 230CE '83 - project for sale 400
Subaru Legacy GT-B '98
kolza is offline Reply With Quote Quote
Old 25-11-2016   #41
i can but it will be next week before i get a chance.
Old 03-12-2016   #42
i reckon you could get that panel out but Iam not sure what would make it worth your while. it would be a lot of work its hard to count the welds without digging out the sealer lots of duble thickness and reinforcement. if you were doing a lhd- rhd then you would have a big job to do the dash panel as well. I will just cut some new holes and patch the old ones.
Old 16-01-2017   #43
i have been adjusting my bulkhead cut some holes. i realized that the mounting points for the steering rack are not symmetrical. So i cut of the saddles, bolted them on to my lhd rack. Got the rack in a good positon tacked the mouts in position. removed the rack and welded them up. heres the pictures.
there is a rusty bit under the battery i will cut that part out of lipstick and weld it in, i may be able to move over some steering column mounts and heater cut outs in the same job. iam not sure if its worth the hassle yet.
ID:	176084   Click image for larger version
Likes Sjvarley, AndyPanda4x4, kolza liked this post
Old 11-02-2017   #44
Iam gona need a new dash fabric. My old lhd one is black vinyl. Just been in spain seen some marbelas with black dashes but not the same as mine.
Old 11-02-2017   #45
Hey kozala here is a closer look at bulkhead removal
(T) Ulysse 2: Headlights RHD to LHD Conversion. Mr Sheen Ulysse 0 14-08-2014 12:58
(G) Rhd / Lhd headlight conversion roymck Barchetta 8 14-08-2012 13:55
(T) rhd to lhd light conversion Casasoleen Doblo 4 06-06-2012 14:04
(T) RHD to LHD conversion... Kirkers X1/9 7 26-12-2009 23:51
(T) LHD to RHD Conversion X 1/9 1300 Kirkers X1/9 0 27-04-2009 14:27
