Hello everyone!
Decided i would start a new thread about my problem. The car previously had a issue with the ignition module which caused the car to stall. I replaced the Vacuum advance unit, ignition unit and the pick-up sensor and the car was running smooth.
A couple of days later the Panda developed a nasty habit of not starting ?
I replaced the cold air sensor by the intake manifold to no avail. I also tested the fuel pressure on idle to 0,9bar, is this the correct pressure?
Yesterday when i drove the car it began stuttering and i could only keep it running on full throttle... i figured this is related to my starting problem.
The car is a 4x4 1000i.e(injected) with the 999cc fire engine.
