Old 22-06-2016   #16
Steyr driven
denis4x4 has donated!
Slovenia
Re: alternative front coil springs for panda 4x4.
Yes, that is fine, I don't mind comfort in utility car.
I'll check in with few more pics after finished.
denis4x4 is offline Reply With Quote Quote
Old 01-07-2016   #17
Steyr driven
Slovenia
First coilover partially finished.
What concernes me is bending of coil. It is seated as it should be up and down.
Also, top bearing is hard to rotate by hand, I expected flawless smooth motion. All cleaned and regreased.
Can't compare with other side, as I can do only one side at a time, because of space problems.
ID:	169209   Click image for larger version
Old 01-07-2016   #18
Panda Wanda
kolza's Avatar
Trader Rating: 1
kolza has donated!
Quote Originally Posted by denis4x4 View Post
Carry on, nothing wrong with the coil, will sattle down after few days.
Sisley '89
Formula '91
W123 230CE '83 - project for sale £400
Subaru Legacy GT-B '98
kolza is offline Reply With Quote Quote
Old 02-07-2016   #19
Steyr driven
Slovenia
Gained 4.5cm with felicia 10.7 wire. Perfectly fine. Won't touch rear for now.
I think still a bit too much camber even at max out position of top bolt- 4mm, but it might settle.
Second shock was still functional, and it has more rebound and less compression, than monroe shock.
Old 12-02-2019   #20
Portugal
hello, I rode the springs of the rover 25 in my panda, and now it was higher on one side about 1cm, is it because it still has not aligned the direction?
Estrada is offline Reply With Quote Quote
Old 08-05-2019   #21
Portugal
Quote Originally Posted by Estrada View Post
Hi, this problem is solved, i just turn the up bearing for other position and work fine.
Now the problem was wen i run back, the wells open and still with positive camber, if I run forward itís ok... can anyone help me?
Old 31-05-2019   #22
Yes itís the toe/out. if the front of wheels are not straight pointing in towards the front simple method is set car on a very flat surface push backwards the tyre fiction is drawing down the spring. Use a 11 mm and 20 mm spanner to adjust off the steering tie rod equally each side untill the draw down is less try this a few Times by measuring Bonnet height say 3 - 4 mtrs apart
Sjvarley is offline Reply With Quote Quote
Old 23-09-2019   #23
Portugal
Quote Originally Posted by Sjvarley View Post
Thanks, but iím affraid, if I do this I lose the good alignment off the wells...
(G) Alternative to The 4x4 Panda? TwinAir Newbie Panda (2012+) 19 25-01-2015 15:52
(G) Front coil springs atkinbrown Ducato 6 15-06-2014 18:04
Could be an interesting alternative to a panda 4x4 StevenRB45 Non-FIAT 0 09-07-2013 11:44
(G) Alternative to Panda 4x4 pandacross Panda 5 12-10-2006 22:52
