Bleeding Knuckles Patron member Joined Dec 27, 2014 Messages 1,133 Points 363 Location Ripon Oct 28, 2015 #1 Greetings, I need to confirm the Valve Clearances for my classic 500 rebuild - I am using a Panda 30 head on the engine. Can anyone please confirm that the valve clearance is or is not the same as the 126 engine head?? Thanks Ian.
FIAT126 Patron member Joined Nov 16, 2009 Messages 129 Points 54 Location Tunbridge Wells Oct 29, 2015 #2 The valve clearances are the same as on a 126 in-0.20/ex-0.25. Also if you have a "hot" cam the settings change a bit.
