FIAT Auto Specialist Team
Thread Tools
Old 21-06-2015   #1
I Void Warranties
Dragon Man's Avatar
Dragon Man has donated!
Fiat Panda Classic Light bulb list
I have seen it a few times where someone has used the wrong fitting light bulb in the panda classic. i write this in hope that it will be of use to someone in the future. This bulb list is based on the mk2 Panda (1984-2003) however my guess would be that the bulbs are the same in the mk1.
All bulbs for this car are 12v.
"P45" or "R2" fitting bulb for the main headlamp. NOT a H4! (unless you have a Seat Marbella.. they use H4 bulbs.)
"BA9s" 4 watt for the pilot/side light bulb.
"BAY 15d" 5/21 Watts dual filament staggered pins for the brake and tail light bulb.
"BA 15d" 21 Watts single filament non coloured for ALL corner indicators, reverse light and fog lights.
"40mm Festoon" bulb 7 Watts for the number plate lighting and the interior courtesy light.
"T10" wedge bulb 5 Watts for the side/wing indicators AND the battery warning light in the dashboard.
"T5" Wedge bulb 1.2 Watts for ALL OTHER dash indication/warning lights, speedo illumination, switches illumination*, blower fan control illumination*,
clock illumination*, even the cigarette lighter*. *model specific.
i think that's all of them.. let me know if i have missed any.
a note on dash bulbs in most older Fiats. in some cars you have to replace the bulb and socket, but with these kinds if you "pull" the glass part of the bulb away from the socket it will come out. here is two pictures of the larger T10 bulb and the smaller T5 bulb and sockets:
Most of these bulbs can be changed for LED types however please do read the following:
so LEDs.. they consume less power as they are lower wattage (which saves more fuel/better MPG), often brighter than the original filament bulb, and supposedly live longer if you buy good quality bulb replacements. oh and you can also get them in different colours.. and auto colour change!
All of the internal bulbs bar the "Battery warning lamp" in the instrument cluster can be changed to anything (colour, brightness.. anything!). legally. so long as there is no light coming out of your car that is distracting to other road users, you should be fine. however it would be at your own risk. the only reason why you can not change the battery light bulb is because the alternator needs it to excite (or kick start) it to start producing power. in short, replacing this with an LED will cause your alternator to stop working. you "Could" make an LED and solder a resistor across it to get the same resistance the original bulb has, then try it. that may work. you can also try a "Canbus error free" LED bulb in it as they have a little load resistor that fools modern cars into thinking the bulb has not blown (Due to LEDs consuming far less power, the modern car's computer detects them as "blown bulbs". something us classic Panda people don't have to worry about ).
Externally, changing bulbs to LED is at the vehicle keepers own risk. UK laws state that original vehicle lighting should never be altered from the original specification.. or so i have been told. i have also been told that so long as the bulb is "E" marked, it is fine to be used on your vehicle.
if you do plan to go all out and start playing with vehicle lighting colours be sure to check up with your local laws! As said, any modification you do is at your own risk.
i hope this helps some one out in the future!
Thanks Bougainvillea Rosso, nitro_warrior thanked for this post
Likes lukmek, P1NKY liked this post
Dragon Man is offline Reply With Quote Quote
Old 24-06-2015   #2
Re: Fiat Panda Classic Light bulb list
Just changed with LEDClick image for larger version
Name:	ImageUploadedByFIAT Forum1435166899.675655.jpg
Great guide thanks man!!
Sent from my iPhone using FIAT Forum
Likes Dragon Man liked this post
lukmek is offline Reply With Quote Quote
Old 26-06-2015   #3
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Quote Originally Posted by lukmek View Post
Just changed with LEDAttachment 156571
Be warned it probably won't last long before failing due to excess heat from the main headlight bulb.
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Panda Eleganza & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 27-06-2015   #4
I Void Warranties
Dragon Man's Avatar
most LEDs start to strobe when they fail..
i would keep spare in the car.. i have a full bulb set in mine stored behind the engine bay sound proofing.. along with a spare clutch cable and 10mm spanner so i can change it out and about... and cam belt... and alternator belt.. with the tools needed to change them with..
Thanks lukmek thanked for this post
Likes lukmek liked this post
Old 13-07-2015   #5
Dragon
I was wondering if an H4 set will be much better...
I changed the original R2 with Phillips R2 +30% and I must admit the difference is minimal. I was also thinking of adding the fog light grill with H3 and connect it to the main beam switch
Old 13-07-2015   #6
Name:	ImageUploadedByFIAT Forum1436771812.067297.jpg
Old 13-07-2015   #7
Number plate and courtesy interior
4 Cm
Name:	ImageUploadedByFIAT Forum1436772264.443586.jpg
Old 13-07-2015   #8
Panda Wanda
kolza's Avatar
Trader Rating: 1
kolza has donated!
4 Cm
Attachment 157375
You can have different Wattage in this"C" bulb package 5W, 10W etc.
if someone have some spare time please read thru Reg.37
http://www.unece.org/fileadmin/DAM/t...gs/R037r7e.pdf
Sisley '89
Formula '91
W123 230CE '83 - project for sale 400
Subaru Legacy GT-B '98
kolza is offline Reply With Quote Quote
Old 13-07-2015   #9
I started reading and it was quite interesting... But in real world I doubt it can be "unlawful" having some number plate lights that are not original fitment.
We for sure try to use more advanced technology like the LED bulb
I changed mine with led and I think it should be ok for the Italian police😄
Old 13-07-2015   #10
PANDA!!
Freebo's Avatar
Freebo is part of the official FF Events Team :)
Freebo has donated!
Ghost Ball Champion
Likes Dragon Man, lukmek liked this post
Freebo is offline Reply With Quote Quote
Old 23-08-2015   #11
Will an H4 upgrade from R2 make a worthy difference?
I found the Phillips R2 +30% not much brighter
Any advise on H4 bulbs?
Old 24-08-2015   #12
I Void Warranties
Dragon Man's Avatar
H4 bulbs require a little adaptor plate. my personal experience with them is to just get the R2 Halogen bulb. even then it seems that the beam pattern will be off.
as far as headlamps go, fitting auxiliary lights really help a lot..
Old 24-08-2015   #13
Trader Rating: 2
H4 are not a direct fit and will only work with a conversion plate, better off sticking to upgraded P45T based 55/60watt bulbs really.
Old 24-08-2015   #14
Any link to get the P45T 55/60w bulbs?
Old 24-08-2015   #15
Trader Rating: 2
http://www.ebay.co.uk/itm/Bulb-h4-12...item48816f485a
Thread Tools
