- Jun 17, 2011
- 144
- 63
Okay, so I'm looking to swap out my fiat panda 1litre fire engine (L reg) for a more powerful alternative. However I'm looking for a swap with as little work as possible. None, if not MINOR, body cutting and no change of gearbox and drive shafts.
I've got the idea that a 1.4 16V punto engine is pretty much a direct swap. Same gearbox and drive shaft etc. I'm aware I will need the engine loom and fuel pump change.
This will be my first swap so please forgive my naivety. My questions are:
1. Is it possible to use the original box and driveshafts?
2. Am I correct in thinking the Punto 1.4 16V is a 'straight swap', if so what age? If not are there other fiat/lancia alternatives?
3. What list of components will i need to make the swap?
P.s. I have access to all the equipment required for the swap and have a basic degree of mechanical knowledge. This is essentially a project for my own development so am fully aware of the effort and work involved.
Any help would be greatly appreciated.
