Thread Tools
Old 10-09-2005   #1
eh?
Trader Rating: 1
Tony M has donated!
removal of steering column plastics...
Is there an easy way to get to the ignition release... I want to exchange to cylinder which is easy enough to do, but getting there is a bind with the plastics on. Any workarounds for this ???
Tony M is offline Reply With Quote Quote
Old 10-09-2005   #2
Trader Rating: 1
Re: removal of steering column plastics...
This is a hard job I did it on my panda and I cut up a coat hanger and bent it into the right shape and pushed it up the back and with a bit of poking and pushing I got it out.
Grande Punto Sporting mjet
Fiat Nutter is offline Reply With Quote Quote
Old 10-09-2005   #3
eh?
Trader Rating: 1
Tony M has donated!
Quote Originally Posted by Fiat Nutter
This is a hard job
Tell me like it is why don't you...
Quote Quote:
hmmm that's a bit of a jiggery pockery technical tip there...
but i think you are barking in the right direction... it's gotta be easier than stripping the steering column down to it's skinnies.
Old 10-09-2005   #4
Don't polish it, DRIVE IT
pandafan has donated!
This sounds like a typical Saturday night, with a lot of the drink taken 1 I'd ask again tomorrow...
www.hawortharts.com
pandafan is offline Reply With Quote Quote
Old 11-09-2005   #5
eh?
Trader Rating: 1
Tony M has donated!
OK i found a pretty good technique not involving any coat hangers (didn't have any) but utilizing a common 3mm allen key.
1. release the plastic retainer (bottom screw)
2. move the plastic over so that the cylinder is visible and make sure you move the wires from the column arms.
3. using the light now coming in from the hole for the ignition locate the slot
4. insert allen key through the hole for the ignition and position while view through the various holes below the steering wheel.
5. push up and avoid getting cramp
6. cylinder should slide out if you press the parking lights button.
please bear in mind that these instructions carry a full denial policy.
Old 12-09-2005   #6
Impressed
www.hawortharts.com
Old 12-09-2005   #7
Go on the Fiats!
Steven's Avatar
Trader Rating: 8
Steven has donated!
Good job. Rep worthy.
2015 Fiat Panda Pop
Steven is offline Reply With Quote Quote
Old 12-09-2005   #8
eh?
Trader Rating: 1
Tony M has donated!
Quote Originally Posted by Steve
I got a power up!!!
Thread Tools
(T) Punto steering column to Cinq? 190daj Cinquecento / Seicento 3 30-07-2005 18:20
(T) rattling under steering column dbeattie Punto (Mk2/2b) 8 23-07-2005 09:50
rattling under steering column dbeattie Lets Talk FIAT 4 17-07-2005 16:00
(T) Steering Column Problem pjp Stilo 7 11-01-2005 17:29
(T) Hot steering column Adamski Cinquecento / Seicento 12 25-10-2004 00:14
