is that a lotus europa trying to hump an aw20 in the background??
Ha Dave, good to see there's an update ! Actually facebook brought me back here to check progress. Again, if you willing to share info about wiring up the lump or an ecu map maybe even, you'd make my day.
Good build !
What gearbox are you using Dave ?
As i am running the setup based on the 1050CC Turbo engine i have the A112 Abarth 5 speed coupled to it. But because i am runnig it in a 127 Brazil it is easyer for me to run the 128 type gearbox which fits right in the frame and mounts.
If you have the A112 Abarth type gearbox you could quite easily change gear setup because this 5 speed is used in many types. The 128 box is stronger though, bigger diameter driveshafts and tripods as well. Worth looking into if only for future developement.
O
M
F
G
That is amazeballs.. you happy with the work? they always look mint in pics lol
