Thought it might help spur me on to get this done... and posting on progress will be a good way of procrastinating said progress
Not done a clutch since Bedford CF... or a transverse clutch since I did my mini van in 1970 I was a nipper!
Now I'm into codgerism - forgetting where I put the tools. When I find 'em - I forget what I wanted 'em for lol
so some crossed off already:
1) Disconnect battery (only 'cos it's knackered lol)
2) Remove starter motor
3) disconnect exhaust pipe at manifold
4) disconnect reversing lamp lead
5) disconnect speedo drive (easier from below)
6) drop gearbox oil
7) disconnect gear linkages
8) remove fixed gear lever mounting from transmission
9) remove front wheels
10) split ball joints from hub carriers
11) remove calipers (hang aside on wire supports)
12) disconnect steering tie rod ball joints
13) disconnect clutch cable
14) unbolt transmission lower mounting
15) undo driveshaft gaiter retaining plates
16) remove flywheel cover plate from below
17) support engine from above with bar
18) unbolt flywheel housing
19) support transmission with trolley jack
20) disconnect top mounting
21) lower transmission onto jack
meanwhile:
22) save up for clutch kit...
1,2,4 & 13 - 'cos they easy...
no blood spilt yet... but watch this space
6) drop gearbox oil
meanwhile:
