Technical Valve Shim Removal
Leek, Staffordshire
Decided it was time to check the valve clearances on my CLX today as the engine has got a little tappety recently. All are within tolerance apart from one which has closed up a little too much. However I am struggling to remove the shim, seems like I will have to modify a screwdriver so i can get the correct leverage and push the valve bucket down without pushing the shim aswell but just wondering if anyone has any tips on how to do it?
It's a Panda
They make odd noises
Get over it :p
Not when it didn't do it before, anyway I've found the source of the noise, it seems when I changed the spark plugs a couple of years ago I didn't tighten number 3 up properly:eek:, so it has worked loose and the noise was air being forced up the thread. At least it was a simple fix and I know the valve clearances are correct now.
Well there you go then, always worse when the problem was self created :rolleyes:
Pinky started making some loud clonking noises - I think it's the back bumper flapping around, or the exhaust. Found green garden string in the back but no cable ties.
Surely it's a condition of Panda ownership to have cable ties in the boot :confused: :p
Clearance is 0.23mm, should be 0.30mm. Size is not marked on the shim but it measures as 4.03, presumably it was originally 4.05, yet the clearence is still too small:confused: I've ordered a 3.95mm shim which I should get on Tuesday from my local dealer. £8 plus vat:eek:
For future reference. Valve shims are shared between different makes. After much searching when I did my engine a couple of years ago I found this lot.
http://www.eurocarcare.net/
£2.40 (y)
http://www.eurocarcare.net/timing/8290.html
I've used Big Mick, there, for quite a few things, now -- for both the Punto and Mk2 Panda. Not only is he the most helpful guy on the planet (even willing to do business by email, because I'm so deaf...); but his prices are pretty competitive; and, if he doesn't have something in stock, he'll either source it for you, or try and find you a cheaper alternative -- even if it's from another supplier. Can't speak highly enough.... :worship:
PS: I should now go and put this in the suppliers sticky, shouldn't I...? :eek:
