- Aug 21, 2012
- 169
- 71
Can I call on the experts again? Trying to resolve a small problem where the exhaust pipe approx 50cm back from the bottom of the manifold rubs on the bottom of the car on the heat shield whenever the car is moving in reverse or under hard engine braking.
The local tyre fitting place looked at it when they changed the tyres and told me the mounting was broken. I've had a look and not so sure. It looked like the first section of exhaust pipe might not be on straight as it was seriously close to the bottom of the car in one place and not others. I slackened the bolts and twisted the section round slightly to level it and the problem is much better but still there.
Looking under the car with it lifted up, there is a gap between the bottom of the rubber stop and the mounting plate. If I put the car in reverse (brakes on) and let the clutch up, the torque rotates the engine and the gaps between the rubber and metal closes by the 5mm or so allowing the exhaust to touch the body.
The bolt travels up and down with the metal, appearing fixed to it, sliding in and out of the rubber part.
Should this be a fixed assembly or has the bolt sheared inside the mount somewhere. Here is a pic, hope it's clear for the experts to look at ..
