Technical 4x4 fuel tank and filler pipe swappable with non 4x4
The East Midlands, Derby.
Hey guys and girls,
Thought it would be a good idea to make a new thread (after using the search feature i might add) asking if the filler pipe and tank from a carbed 2x4 would all fit into a 4x4 panda?
I ask this as now you cant get the 4x4 fuel tanks in the uk (without importing one from italy for big money) if it is doable.
You reckon the round filler pipe would rub over the oval one? even though the oval is bigger?
Anyone have both pandas that could do a quick measure and see if the 2x4's filler pipe would rub on a 4x4's wheels for me?
If it does not, a standard 2x4 panda tank and filler pipe could be used :LOL:
Thanks guys!
2wd has the omega axle so mounting points may be an issue. I'm away for 12 days now so can't check this for you at the moment John, but will when I get back if you're not sorted.
