microphonehead
hello,
A couple of days ago I was driving along quite happily when the accelerator suddenly went floppy and completely unresponsive. I thought the accelerator cable must have either snapped, come off at the pedal or come off at the carburetor. I can see it is still attached at the pedal, so I've been trying to see if it is attached at the carburetor, but I can't see where the damn thing is supposed to be.
I'm sure I've got the right haynes manual, it says it's for 1981-95, 769cc, 903cc, 999cc, 1108cc. I have a 91 750l, with a 769cc engine, so you would think it was the right manual. However the pictures look different from reality and I just can't work out where the cable is supposed to be.
here's some pictures of the engine(as you can see, it's a nice sunny day in glasgow today):
As you can see, there is a green box sitting on top of the carburetor, it says hot air filter on it. It doesn't appear in the haynes manual...
I can see some cables on the side of the carburetor, I'm sure one is for the choke though, the accelerator cable in the haynes manual has a distinctive housing and spring on it, which I do not see anywhere.
Can anyone enlighten me as to where I might find this elusive cable?
Also, I spoke to someone at a local garage who told me I can only get a new replacement cable from fiat, for about 60 quid, which sounds a bit expensive, surely there is a cheaper way to get hold of a cable that fits the specs needed?
Any help and advice much appreciated.
thanks,
Richard
thanks,
Richard
