when i was removing the fuel tank from donor i chopped the fuel lines near the pump in tank, well i was cleaning it today reading to fit and removed the white connector from pump, fine, removed the red on and it broke, AAARRGGHHHH....
well can you buy replacement ones or is it a new pump for the tank.
its a 1.0 spi donor with a large pump fitted, it has 2 different wire block connectors that attach as well.
hope someone can help or advise if replacement bits available, oh they have an 'O' ring on them to make the seal held down by a metal plate
thanks
kevin
man this resto is well hard ??? and soul destroying when summat breaks
thanks
kevin
