Thread Tools
Old 06-07-2011   #1
Arrow testing fuel pump/pipes
is there an easy way to test the fuel pump and pipes?
still trying to work out why my 1l injection engine is running rich when idling..with high co
being picky really, but just have a gut feeling...
peterainbow is offline Reply With Quote Quote
Old 07-07-2011   #2
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Re: testing fuel pump/pipes
Have you done an ECU reset or checked the lambda sensor?
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Panda Eleganza & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 07-07-2011   #3
yes done the reset and had to replace the lambda sensor a while back
although i must admit was with a generic one of ebay
Old 07-07-2011   #4
lightweightmick has donated!
changing the manifold coolant temp sensor sorted my CLX - cost about a tenner as I remember (if reading low will deliver more fuel via ECU - ie. the sensor thinks the engine is cooler than it actually is and calls for a richer mixture)
I think there's a thread on this some years back where we compared readings of resistance of the unit at different engine temps...(?)
It's most unlikely it's the pump that's delivering too much fuel IMO...
Ellen - '87 Ducato 2.5D Elddis Autoking 630CK
Viv - '02 Seicento 1.1 SX
Billy - '02 Seicento 1.1 SX
lightweightmick is offline Reply With Quote Quote
Old 07-07-2011   #5
Trader Rating: 1
If the fuel pump is delivering too much fuel, the pressure regulator will let more fuel back to tank. The pressure regulator would need to be at fault for there to be too much pressure in the lines.
Panda 4x4
Panda 4x4 project
VW Type 3 Fastback
Chrysler Voyager
nitro_warrior is offline Reply With Quote Quote
Old 07-07-2011   #6
i've checked the resistance on the temp sensor seemed ok
i was thinking more that not enough fuel being delivered and thus when going up hill causing a starvation and stall and this behaviour fooling the ecu into causing more in general to be pumped
but only a grasping at straws as can't work out what else could be, bad at normal/low idle ( high co , smelly , can stall uphill when cold ), but ok when warmed up and at fast idle ( mot passed at fast idle )
am wondering whether to build the ecu monitor to usb thingy mentioned elsewhere so i can get readings from the ecu...
Old 07-07-2011   #7
How do you know the readings are true - what have you got to compare against?
Old 07-07-2011   #8
Quote Originally Posted by peterainbow View Post
to test a fuel pump and lines you would need a fuel line pressure gauage, to check why its running rich at idle you will need an oscilliscope to check the lambda and injector pulse timing and or ignition burn time.
failing these garage items I would suggest an obd scanner - you can buy a generic one for around 40 - code read and post up what you have, I would not worry about the fuel pump as previous post, too much fuel - returned to tank, to little fuel and cutting out.
lambda's are sensitive - ebay jobs are suspect and aftermarket ones may give fail readings to the ecu or not work altogether.
I know costs are always an issue but its like looking after yourself, put effort into it and look good, go 3 days without sleep and your knackered.
Hope this helps
keithmw is offline Reply With Quote Quote
Old 07-07-2011   #9
regarding temp sensor...i compared the resistance readings aginst those that were in another thread, but in any case there was a good shift in resistance from when cold to when hot
Old 07-07-2011   #10
Quote Originally Posted by keithmw View Post
yes been thinking about this myself...
anyone recommend a good value for money sensor then?
oh and sleep what is that?
Thread Tools
(T) In need of Power stearing pump pipes georgemill0 Ulysse 1 07-11-2010 22:01
Fuel Pressure Testing bikecrazy Tech Talk 0 13-08-2010 11:24
Fuel Pressure Testing bikecrazy Newbie Central 0 12-08-2010 22:01
(T) Testing a fuel pump jiminwatford Cinquecento / Seicento 6 09-03-2009 23:30
