General Panda Parade
MrBlonde
Shire O'York
Lo everyone - i need of some wisdom... Had a look at this car today, but not driven it yet....what y'a think?
L-reg Panda Parade (With the cool big fabric sunroof)
1000cc FIRE
90000 miles
9months MOT
no TAX
Immaculate Condition, and I mean like stunning, looks new and Shiny, tho a couple of small dings, no rust, tho looks like one of the indicators by the headlight has been hit with a door - its a bit mashed up.
Little service history (although apparently cambelt recently changed)
Metallic Green
And the man wants £475 for it - is that fair, over the top etc? I'm gonna have a test drive in a few days - so anything to look out for/poke at?
Cheers (y)
my mum had a k-reg parade in the greeny/bluey colour
it went beyond 90k, clutch was on its way out though as it was heavy and no bite, but thats something that could be expected, other than that nothing ever broke down on it, she used hers as a courier van from new, so lots of stop starting
im sure the more knowledgeable will be along with a more mechanical answer
That's a bit on the high side, with no tax, at that mileage.
Will add to the "look out for" list later.
Yeah - 475 did seem a bit on the high side, esp. as immediatly i'd have to go and Tax it. I've had a peek on ebay - but this one is just done the road from me, parked on the guys lawn, so its handy to look at. I'll give it a test drive see what happens, but if you guys could list a few things to look out for to make sure its a good one, that'd be grand.
Ta
Ta
Hi. I'd agree that £475 is on the vertical side of steep.
However, things to look out for. Well, let's go for the really obvious one first. As it's got a big fabric roof, check the seats for wet spots and a smell of damp.
Next is the synchromesh on third gear. It's quite normal for it to be a bit resistant so if double-declutching is necessary, that's not such a bad thing. The test here is 'how worn' rather than 'is it worn'. Although, in saying that, it would have a later design gearbox so might not be too bad.
As it's a '94 model, it'll have servo assisted brakes. Check this functions when starting-up.
The bottom of the doors are a good place to check for rust. It starts in the bottom corner (furthest from the hinge) then works horizontally and vertically from there. If everything has gone wrong (because it's only 11 years old), the rear arches might show signs of rust, but I'd doubt it to be honest. However, whilst you're there, put your fingers inside the rear arches and you'll feel a lip. If there's a load of mud in there, it's likely to rot the arch, so if you're going to buy it, get that out and ensure it's clean every time you wash the car.
When out on the drive, see that all electrical stuff does what it should. Earthing faults aren't uncommon but most of these can be rectified by cleaning the spades that are mounted on the inside of the nearside wing. If you can, put on the dipped headlights, wipers and hazard lights. That's a good test of how strong things are.
If the front wiper doesn't self-park, that's nothing unusual. Might also find that it only does monsoon mode and not intermittant wipe, but these (and the lack of self-parking) are the result of worn bushes. It's something you learn to live with ;)
Other than that, listen out for odd clunking noises when cornering, but be aware that rattles are commonplace and change from week to week :)
Hope this helps you.
Good luck!
Hi
Check out the white one in classifieds £120 and it looks immaculate,don`t know how far you are from sunderland but it might be worth the trip.
I`d have it but Sunderlands a long way from Cornwall
Adrian
A draft version of how to buy a Panda - bits collected from all over.
If others can add comment, perhaps one of the moderators can make it a sticky posting.
The biggest killer of Pandas is rust - there are some disturbing pictures in this Sisley thread
other places to look are:
bottom of the doors, front or back, either side.
When your doors rust they're difficult to repair or replace.
Check the bottom of the sills under the car, where the panels all come together at the lowest point - this seam should be nice and solid, and the same width all down the length of the car - any "fat bits" are corroding badly inside.
While you're down there check the driveshaft boots for splits.
Check the wheel arches too - outer edges front and back - and also the seam inside the rear arch where the top, middle and bottom of the car are welded together. Look out for "fat bits" on this seam too, if it gets very bad you get a hole inside like the first attached picture.
Check the tyres for odd wear patterns, and condition, while you look at the wheel arches.
Open the hatch and lift the floor matting, check along the edges for rust bubbles.
Fold the rear seat and check for bubbles where the rear suspension arm brackets are mounted (this is is the other attached picture, the view is of the passenger side looking towards the rear of the car - the indentation to the left is where the rear seat base locates).
Make sure the bonnet can be opened (might be a two man job) and check the oil colour on the dipstick - it'll probably have been changed recently anyway, but worth a look.
Take the oil filler plug out - there should be no signs of "mayonnaise" in there. If there is you might have head gasket problems.
Look to see how much oil there is splattered about on the engine - some leakage from the camshaft cover is common - but less is better, unless it's been steam cleaned very recently. In which case, what are they hiding??
Check the floor under where it's been regularly parked up - you'll soon see if there are serious leaks.
Make a note of the VIN number for later.
Take the top off the radiator header tank (careful if it's hot), check the antifreeze mixture looks either green or blue, but not clear water. Look for oily residues, or mayonnaise, in the coolant - there shouldn't be any, if there are you probably have head gasket problems.
Put the filler cap back on.
Before you start it up, see what dash board lights are lit:
Brake, ignition, oil, and (briefly) engine management lights should all be on.
Start it - it should start without touching the pedal (as it's fuel injected) and run evenly and be free of loud tapping or rattling noises.
All the lights should go out, except the handbrake warning.
Don't be fobbed off with "it's just the bulb" if a warning light is out.
Back under the bonnet again - see if the coolant pipes get stiff quickly, if so you're looking at a head gasket problem.
Let it warm right up - the fan should cut in at about 90 on the gauge.
While it's warming up check all the lights, indicators, wipers, and washers.
(The front wipers have two speeds flat out, and intermittent flat out. The back washer is operated by pushing in the rear wipe button, and holding it in, when you let go the rear wiper runs non-stop until you press the button again.)
Also check the heater is working, and check the fan for operation on both speeds.
Check all the locks - hopefully the same key.
The clutch operation should be reasonably light - as mentioned above, a very heavy pedal is common towards the end of the clutch life, possibly because the driven plate is sticking on the splines.
Foot brakes on this Panda should be good, and no shock to a driver of any modern car, due to the servo.
Press the brake pedal fairly firmly - keep the pressure on for several seconds... The pedal shouldn't sink towards the floor.
It should pull up in a straight line.
Check for fluid leaks around the servo, and by the wheel cylinders.
The handbrake should hold the car on a slope without too much effort - but it's one of the weak spots on the car: use it as a bargaining point.
When driving, the steering should be very precise, and not pull, or tend to go left or right if you loosen your grip a bit on the steering wheel.
The performance should be quite lively, with lots of pull from low revs - it should feel a bit "under geared".
Any hesitation, or spluttering, or needing to keep the revs up (or excessive steam from the exhaust) is a bad sign.
The gearchange might be a bit vague, and there may be some difficulty in selecting 5th gear - use it as a bargaining point - there should be very little gear noise.
The synchromesh should be good on all forward gears, as this one has the later gearbox.
Check the condition of the opening roof(s) - the outer edge stitching will probably have gone by now, and it will be a bit noisy at speed, but it shouldn't flap about when closed with the windows shut.
It should all line up with the roof, and the catch, when closing.
Both the rubber straps (for keeping the roof open, or partially open) should be there, without any rips.
The most important sunroof bit is the leading edge, where it is riveted to the roof: older used ones tend to split here. When it tears all along the front edge you need a new roof...
Don't forget to ask how long they owned the Panda, beware the "I'm selling it for a friend/aged relative/ etc" line, look at the V5 for last issue date, and number of owners.
Large number of owners may be a problem car, short last ownership ditto.
Check the VIN number is the same as the car (and MOT).
If the name isn't the seller you may be looking at a "home trader" who has got it from auction/trade in, and is looking for a quick profit.
If you don't want a 100+ UKP bill at the next MOT, get it done before the purchase - with emphasis on the gas test: the CAT will be tired by now, if original.
If you've got through all that, and ticked every good bit, and not found any bad, give or take the state of the tyres, preferably with lots of "history*", you've probably got 400 and odd UKP worth of Panda.
Regards
John H
Many thanks for the things to look out for - i think i'll have a look at it in a few days, and i'll let you all know what happens....
try going to the auctions, as i have seen good pandas go for next to nothing, just recently a panda 1000 went at my local auction for £20, it was a 1993 K reg, with mot til november, but no tax (i think its the law that auction cars dont have tax?), i recently got a 1989 903cc panda for £15 off ebay, including a good spare gearbox.
Wow - 20 quid sounds like my kind of money! I'd totally forgot all about the auctions...Anyone know of any good ones in Essex? (where i currently am, despite my avatar!)
if you dont mind travelling, a VERY cheap auction is near newcastle upon tyne, the website is www.smag.co.uk
here are a list of cinq's that recently went at the above auction
cinq S 1000cc, 1997 R, mot sep 05, 67000 miles £500.
cinq sporting 1100cc, 1997 P, mot june 05, 69000 miles, £500.
cinq S 1000cc, 1997 P, mot april 05, 48000 miles, only £80.
or even a seicento 1.0 SX, 1998 R, mot june 05, with 39000 miles going for only £600.
but the best bargain was this....
FIAT SEICENTO SPORTING 1.1, 02 REG (2002), 55000 MILES, £950 INCLUDING THE REMAINING 2 MONTHS FIAT WARRANTY...WOW..
AppleSei said:
950 quid!! :eek: i wish i was that buyer......
ok i was reading on the last page that the wipers having intermitant not working and non self homing working is a common problem? ok if it is how do i fix it it is vvvvvvv annoying
