Thread Tools
Old 30-04-2011   #1
Help Horn not working?
Finally took my panda to be mot in the week and it failed on one thing the front brake line. Just replaced it this morning and brakes fine but now the horn isn't working.
Everytime I press the horn the lights go on and the fuel gauge rises so I'm guessing its an earthing problem. I've gone over every part of the new brake line and its not touching anything it shouldn't be but problem with horn is still there.
I;ve recently put a stereo in so thought might be this but i've checked it all and still got the same problem.
Does anyone have any suggestions??
starsky is offline Reply With Quote Quote
Old 30-04-2011   #2
Beware the Panda Face.
purple haze's Avatar
Trader Rating: 3
purple haze has donated!
Saudi Arabia
Re: Help Horn not working?
As you have said...you have an earth problem. Check your hedgehogs.
Sounds like you know what your doing....
Or ask Hutch he might know...
If the forum has saved you money or a garage bill why not donate 1 to keep the knowledge coming. You know it makes sense
Quote Originally Posted by Wee Smurf View Post
I don't have a classic Panda but regularly come here. It's much more friendly in the classic section than the nuovo section.
purple haze is offline Reply With Quote Quote
Old 30-04-2011   #3
I had a complete mare when fitting my stereo last week. Wone min it worked, mext nothing. Same problem with my amps. Checked all earths, they seemed good. Also my fuel guage would rise and dash lights come on.
Finaly i decided to make a new earth strap and bingo, everything works perfectly now.
L7 KVV is offline Reply With Quote Quote
Old 30-04-2011   #4
panda1408 has donated!
The earth strap breaking seems to be a very common problem indeed. Chances are you knocked it whilst doing the brake pipe. You can't see it under the heater matrix either so its a hard one to spot!
1988 Panda 4x4 Sisley
1982 Panda 45
panda1408 is offline Reply With Quote Quote
Old 01-05-2011   #5
Quote Originally Posted by L7 KVV View Post
hi i am intrested in seeing your set up, any chance of pics?
The panda is tight on space so i am wondering where you mounted your ampS and what sort of ice set up your running in general
blackpool is offline Reply With Quote Quote
Old 01-05-2011   #6
Thanks for all your help, I'm gonna have another go tomorrow with your suggestions.
hoping it works, this is the final hurdle then it'll be back on the road. Will post some pics soon.
Old 02-05-2011   #7
Well i looked at earth strap,looks like has been replaced recently so I cleaned the ends etc but still same problem. Just as L7 KVV fuel guage rises, dash lights come on. i've also discovered it does this when lights turned on aswell as horn
I've had the dash out to see if wiring problem from when put in the stereo and cant see any problems.
Any further suggestions would be good as i've run out of ideas. Had two mates look at it and still no luck
Old 02-05-2011   #8
Have you checked the middle connection under the heater?
1982 Panda 45
Old 02-05-2011   #9
Working Seicento at last!
firstcar-Y10's Avatar
Trader Rating: 1
firstcar-Y10 has donated!
I know it's a bit of a 'duh' question but have you checked the connections on the horn itself because it is sited right behind where the brakeline goes through the arch and behind the N/S headlight so given your symptoms it's an obvious place to look and likely to have been disturbed when you've been at the lines.
THE MIGHTY GRUMBLEWEED
firstcar-Y10 is offline Reply With Quote Quote
Old 02-05-2011   #10
The Panda whisperer
VmanC's Avatar
Trader Rating: 2
VmanC has donated!
Race to Excel Champion
Quote Originally Posted by purple haze View Post
Have you done this yet?
VmanC is offline Reply With Quote Quote
Old 03-05-2011   #11
I;ve checked earth under heater not that and I didn't replace the brake line on horn side so didn't disturb that side but I have checked the horn and still no luck.
Old 03-05-2011   #12
Trader Rating: 3
Saudi Arabia
Quote Originally Posted by VmanC View Post
If your not sure what hedgehogs are just ask..
Old 03-05-2011   #13
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Quote Originally Posted by starsky View Post
The horn is a switched earth so the earthing point won't be anywhere near the horn. I believe it's the same as the dash earthing point for the dash lights etc (although can't remember where that is).
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Panda Eleganza & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 04-05-2011   #14
thanks once again for your help will try to locate earth for horn. Fingers crossed its getting very frustrating now!
I don't know what the hedgehogs are (apart from the ones in my garden that is). Any help much appreciated.
Old 04-05-2011   #15
Trader Rating: 2
Hedgehogs are the type of earthing points used on the pre fuel injection Pandas. The ones that normally cause issues and need cleaning are on the inner NS and OS wings under the Bonnet.
Thread Tools
(T) Horn not Working? Reuuk Punto (Mk2/2b) 2 24-02-2010 00:17
(T) Horn not working johnob Punto (Mk2/2b) 3 20-06-2008 00:56
(T) Horn not working GrahamD Punto (Mk2/2b) 5 26-06-2005 13:55
(T) horn not working beau Uno 5 01-06-2005 01:44
(T) horn not working kopite Bravo / Brava 1 22-07-2004 02:52
