Old 24-03-2011   #1
Serbia
Panda 1000 excessive fuel consumption
Hi everyone!
Friend of mine is having huge trouble with his Panda (1000 SPI, my2000). Fuel consumption goes as high as 14mpg (20l/100km)!
Diagnostic tool says:
p0201
p0104
p0210
p0202
p0204
p0302
Trouble is that he lives in remote and desolate part of Bosnia (Republika Srpska) and there are few mechanics. One told him that he should replace throttle body, but I am kinda suspicious, car has only 30k on the clock...
Any ideas what could be the problem here?
Thank you!
Panda Guido
www.panda-club-serbia.com
gibanitza is offline Reply With Quote Quote
Old 24-03-2011   #2
The Panda whisperer
VmanC's Avatar
Trader Rating: 2
VmanC has donated!
Race to Excel Champion
Re: Panda 1000 excessive fuel consumption
High fuel consumption on mine when I first bought it was due to the temp sensor, they're cheap and easy to fit so may be worth a try, it wasn't as bad as 14mpg though .
VmanC is offline Reply With Quote Quote
Old 24-03-2011   #3
Serbia
I forgot to mention: small service has been done (new oil, oil filter, fuel filter, spark plugs, air filter).
Car goes just fine, there is no black smoke from the exhaust, rpm in the neutral is ok...
Panda Guido
Old 24-03-2011   #4
Bougainvillea Rosso has donated!
Unlikely to cause that kind of fule consumption but check function of Lambda sensor.
Panda CLX 1992 & Panda 4x4 1987
Bougainvillea Rosso is offline Reply With Quote Quote
Old 24-03-2011   #5
The Panda whisperer
VmanC's Avatar
Trader Rating: 2
VmanC has donated!
Quote Originally Posted by Bougainvillea Rosso View Post
Yep, good call .
Old 25-03-2011   #6
SAM Site Champion
Dodgy gaskets? But again, shouldn't consume that much
'93 Green Fiat Panda Fizz 1.0 Litre FIRE engine.
Because Vauxhall Corsa's, Ford Ka's, and Citroen Saxo's can bite my shiny metal ass.
Quote Originally Posted by dave View Post
stuck cock, get some one to look at your cock whilst you move slider up n down, or other way around
RhysB is offline Reply With Quote Quote
Old 25-03-2011   #7
Working Seicento at last!
firstcar-Y10's Avatar
Trader Rating: 1
firstcar-Y10 has donated!
with that sort of consumption I think I'd start at the filler cap and work through checking for fuel leaks!!
THE MIGHTY GRUMBLEWEED
firstcar-Y10 is offline Reply With Quote Quote
Old 27-03-2011   #8
The goose is loose!
alexbpl's Avatar
alexbpl has donated!
Sounds like temp sensor (blue plug at back of engine) and also the lambda sensor.
I had this problem too. My idle speed was like 2,000rpm some days. Pretty annoying!
No Pistons FTW
alexbpl is offline Reply With Quote Quote
(T) excessive fuel consumption turbo32 Punto (Mk2/2b) 7 23-11-2009 11:05
(G) Excessive fuel consumption, HELP!!! JRB21 Uno 12 18-02-2008 17:45
(T) Problem: Excessive fuel consumption A1ex Bravo / Brava 24 15-04-2007 08:26
(T) excessive fuel consumption petrolhog Cinquecento / Seicento 3 14-01-2007 22:58
(T) Punto 1.7 TD – excessive fuel consumption isotron5 Punto (Mk1) 7 13-06-2005 14:16
