Old 13-03-2011   #1
Panda 1988 - 1000 CL
TechyWill's Avatar
TechyWill has donated!
Bonnet catch but most of all BOOT catch
Hi
The catches on the bonnet and boot are irritating: the bonnet catch works, but you have to push it to closed with something metal, before you drop the bonnet, or else it won't "catch"... Anyway I can live with that...
What is annoying is the boot. It won't open from the outside. The only way to open is from the inside, using something to poke the catch open so it un-clicks. Then you can lift it. Any solution to this?
TechyWill is offline Reply With Quote Quote
Old 13-03-2011   #2
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Re: Bonnet catch but most of all BOOT catch
Front needs greasing, should be standard practise on any servicing on the car.
Rear needs more explanation. Is the lock working ok??
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Panda Eleganza & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 13-03-2011   #3
panda1408 has donated!
On the boot catch, have you tired pressing on just one side of the button? Sounds abit silly but its what you have to do on my CLX, . When I looked at the catch it seemed like it was because there was some movement in the rivets that hold it together.
I also have a similar problem with the bonnet catch on my Sisley, it worked fine then I moved the release cable under the dash and it wouldn't catch without having to do what you do, however now it catches on its own no problem again
1988 Panda 4x4 Sisley
1982 Panda 45
panda1408 is offline Reply With Quote Quote
Old 13-03-2011   #4
TechyWill's Avatar
Apparently the metal "tongue" from the boot button isn't reaching far enough to trigger the catch to open...
The key works fine on the boot. Although I wouldn't know. The boot has had this prob since I bought the car and it behaves like its always locked. (I think; not sure if the button depression varies or not, but at the end of the day, the boot isn't opening either way.)
Old 13-03-2011   #5
Bougainvillea Rosso has donated!
You can adjust the plate of the catch where it attaches to the front panel. That may be what's required. Take your boot lock apart and have a look at it. You may just need a new barrel - they are pretty rubbish and have a tendency to not last long.
Panda CLX 1992 & Panda 4x4 1987
Bougainvillea Rosso is offline Reply With Quote Quote
Old 15-03-2011   #6
a73uk has donated!
y boots done the same thing since I`ve had it, as have a couple of my previous ones.
The one now `clonks` when you press the button, but it doesnt open uless you yank the bottom corner of the bootlid at the same time.
The button sticks in too.
I`ve left it because its unlikely that a thief would work that out!
Currently got.. 1981 Fiat 127 Super, 89 Panda 750L, 89 Uno 70SX (1.5), 90 Uno 60S, 93 Uno 45i.e., 2000 Sei Sporting, 96 Jaguar X300 Manual, 99 Jaguar XJR V8, 01 Porsche Boxster, 2012 Fiat 500 Twinair, 2012 electric motorbike..
a73uk is offline Reply With Quote Quote
Old 16-03-2011   #7
Beware the Panda Face.
purple haze's Avatar
Trader Rating: 3
purple haze has donated!
Saudi Arabia
Quote Originally Posted by Bougainvillea Rosso View Post
Think I saw a write up from maybe AlanD about this..maybe worth doing a search.
If the forum has saved you money or a garage bill why not donate 1 to keep the knowledge coming. You know it makes sense
Quote Originally Posted by Wee Smurf View Post
I don't have a classic Panda but regularly come here. It's much more friendly in the classic section than the nuovo section.
purple haze is offline Reply With Quote Quote
Old 16-03-2011   #8
The Panda whisperer
VmanC's Avatar
Trader Rating: 2
VmanC has donated!
Race to Excel Champion
Half the Pandas I've owned have had dodgy bonnet releases, and I've found the cable to be the problem most of the time, it's far too long. It's a system crying out for a redesign, and I may one day modify it to open from a front outside lever.
VmanC is offline Reply With Quote Quote
Old 17-03-2011   #9
Trader Rating: 3
Saudi Arabia
Quote Originally Posted by VmanC View Post
One day??...do it today Vern and save us all this hassle......
Old 20-03-2011   #10
TechyWill's Avatar
Okay what happens is the piece of metal that is attached to the barrel, slips to the right of the bit it's supposed to catch on. Instead of just pushing the catch open, the barrel or the other part is not staying perfectly aligned, so it's not opening. Dunno how I could adjust this seeing as I don't have access to a vice, nor do I have pair of heavyweight pliers.
Just trying to decide what to do next.
EDIT: Yeah I tried pushing the button to one side but it won't work. It needs a new something. (Barrel) Any idea how do I find the part number?
Purple Haze: I tried a search. You're the best person to search for AlanD's write up.
Old 20-03-2011   #11
There was a boot lock on ebay recently. It might still be there.
Old 22-03-2011   #12
TechyWill's Avatar
Cheers.
I emailed a guy on ebay and got a quote 19 inc post. Not sure if a new barrel will definitely fix it though. If anyone else has had the same problem would be nice to hear feedback...
EG. Possible there is something in the boot door that isn't holding the barrel correctly, since the barrel itself doesn't look broken in any way..
Thoughts?
Old 22-03-2011   #13
As I said check if there is any movement in the catch plate, I think it is riveted together, that might be moving when you press the button instead of the catch releasing.
1982 Panda 45
Old 23-03-2011   #14
TechyWill's Avatar
Quote Originally Posted by panda1408 View Post
Everything seems to fit perfectly, no movement anywhere.
(When you say catch plate, do you mean the plate attached to the barrel? Have you taken apart a boot lock before? Read my previous post...)
Old 23-03-2011   #15
I took one apart a while ago and I can't quite remember what it was like, I will have a look at one of mine at some point, probably not until the weekend now though.
By catch plate I mean the plate that holds the actual catch mechanism inside the tailgate.
1982 Panda 45
(T) Bonnet Catch dazrom Punto (Mk2/2b) 2 22-04-2010 14:30
(G) Where is the bonnet catch xathras Bravo / Brava 2 26-12-2008 21:36
(T) bonnet catch! fit4life4ever Punto (Mk2/2b) 5 12-06-2006 00:19
(T) Bonnet Catch hot_fiat Bravo / Brava 1 21-06-2005 16:32
(T) bonnet catch Jayjj Bravo / Brava 0 10-05-2005 23:22
