Has anyone reconditioned the propshaft of their 4x4? Mine is shaking and clunking and sounds like it not going to last much longer ! Can any of the parts be replaced at all?
When I first got the car I got drive shaft gaiters replaced at the front somewhere as the gearbox was leaking oil out them, is that the ones you are talking about ?
Garage also mentioned that they could send the propshaft away to be recondtioned if I couldn't find the parts for them to fit. I have just bought UJ's off ebay that say they are for panda 4x4 so maybe they will be the right ones.
Replacement UJs - these should be OK.
http://cgi.ebay.co.uk/ALFA-ROMEO-FIAT-LANCIA-UNIVERSAL-JOINT-X-2-/360145120034?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item53da526b22#ht_1116wt_1139
Propshaft supports are a bit more tricky. Hard to get in the UK but there are plenty on Italian E-bay.
If you go on Italian E-bay and put in 'SUPPORTO ALBERO TRASMISSIONE PANDA 4x4' using the 'classico' search option, propshaft supports will come up.
There are a lot to choose from but they are all a lot of Coin......
As the rubber on my prop supports had rotted through, I bit the bullet cost wise and bought a pair off Italian Ebay last year. I asked a few sellers first to get an idea of postage costs and also if they were prepared to post to the UK. Initial correspondence with the sellers was by using Google translate but my eventual seller had good English. The pair of supports took a week to arrive.
