Technical Electronic Ignition?
Cymru
Is it possible to replace the points on my Marbella with an electronic ignition??
I am getting damn tired of sorting out those points :D:D
If so, with how much dough do I need to part with if it is possible?
Thanks.
Wow, I didn't realise they were so damn cheap! Maybe I would have converted it ages ago and saved me alot of hassle with slipping point gaps.
I am really not sure what my distributor make is. I know the points themselves are Fiat Marelli, Ignition coil is Bosch..
I don't know which would be a good option as I do not entirely know what I am looking for here.
There are only 2 types of aftermarket electronic ignition, optical and magnetic, both as good as each other, but you do need to know the make and model of the distributor, should be stamped on the distributor body.
