I had a little spare time tonight so I went to have a look at the Sisley to get a feel for what needs done when I start it's restoration after I finish te MK1.
To get to the point I think the original engine is going to need a lot of work. I'll know when i pull it out and start on it.
But, I'm definately not going to put the french Panda back on the road as I'm going to use a lot of it's panels for the Sisley. Also the 99 car has a great engine.
My question to our resident Panda experts is, how big a job would it be to fit the 1999 fuel injected engine into the Sisley. They are both 1lt engines so I presume they both more or less use the same block. My concern would be how straight forward mating the 4wd box up to the later engine. The other concern is the fact that the exhaust on the later engine is at the bulkhead side.
I know I need to use the ECU and will change the key system into the Sisley to as it is the later blue key with the chip in it.
It would make for a sympathetic upgrade to the Sisley, (electric windows, central locking, key immobilizer, injected engine) without losing to much of the cars originality.
Pointers please Panda experts :worship:
