Hello.
It's a 1000CL -87.
My transmission has not been working to well last couple months. Gear changes been a proper workout. Changed the oil, and i saw alot of metal filaments on the drain plug.
Well, the oil change did not work. Ended up only using 1,3 and 5 gear as they were easiest to get into. Well, in desperation, i fitted a axe shaft to the gear lever to make it a little longer, to get more momentum. Worked like a charm, for a week.
This sunday the connection between the gear selector lever and transmission broke clean off as i was changing to 4th gear.
Is this fixable or is it dead?
It's a 1000CL -87.
