FatNote
Hi folks,
Well, after several months of driving my poor Lancia Y10 around after never having quite fixed the problem (I posted a thread about this a long while ago), I finally took it in to a Fiat dealer for diagnosis. 1 hour of work and he'd found the problem - the butterfly potentiometer (at least that's the translation from French).
The symptoms were:
1. poor idle, especially in cold weather... means it could stall often before warmed up... the little solenoid to raise the idle when cold on the injection block (sorry donno the name) wasn't doing anything, unless it got a little push with the finger...
2. a nasty acceleration hole after travelling for 20+ minutes on the highway... or after having driven and then stopped for 5 to 60 minutes. Sometimes this problem would show up, sometimes not at all... very pesky! Closer inspection revealed that the injector's spray became very non-uniform (yukky) in this region of rpm.
So experts, does the butterfly poteniometer seem like a suitable cause for these symptoms?? I'll never quite trust a mechanic if he's not my friend first!
They say only the whole injection block can be replaced... which costs 900 Euro!!! I'll trash the car before that... but can only the potentiometer be replaced?????
A little info: it's a 1990 Lancia Y10, 999cc Fire engine, about 150000kms on the car, the engine has 125000kms cause we swapped it out with another (which by the way had the same problem... a defect in Fire engines???)
Any help would be apprechiated!!!!!!
Thanks!
Fatnote.
The symptoms were:
Thanks!
Fatnote.
